Monster MotorsportChris Nott
    Oct 2009
    Warrington
    24
    wobbly rev needle and periodic revving up to 2000 revs. diagnosis please!
    hi all,
    as specified in the title my 56 plate S3 has a rev counter wobble when idling of around 800-1200 revs and then periodically whilst idling the rev counter will go up to 2000 then back down. The emissions system warning light is constantly on now too. Car drives normally other than this, any ideas of the problem and how much it will cost to fix?
    thanks in advance
    Mar 2008
    Bradford, WY
    788
    Stick it on diagnostics, sounds like a air leak somewhere
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    L80EWY's Avatar
    Sep 2009
    331
    My emissions light comes on now and then and my rev needle dips up and down so any ideas id like to know as well. Mines been on a diagnostics before and didnt have a fault
    BaDD Boi S3's Avatar
    Audi S3-REVO-Digital Designs
    Jul 2011
    South Africa
    40
    Hi There Comunitee...
    My 08 S3 8P is having the same issue as mentioned above... The rev needle fishes between 800 & 1200 and from time to time goes all the way up to to 2000 RPM... When the engine does this though the cars Temp rises as well from 90 - 110 deg.
    I have noticed though that when the Digital Designs 15" hits at high volume that the car idleas steady at 800 RPM - Then the Temp goes back to 90 deg and as soon as the Bass stops then the problem starts again...
    Seems almost like something is stuck and the Bass loosens it up??
    Has anyone found a Solid fix for this on the S3's... Audi dealers seem to be clue / useless.
    Some reported fixes I have come accross:
    Intake Controller Needs to be replaced
    "Rear" Fuel filter needs to be changed as dealers seldom do...
    Fuel Sensor replaced (06E 906 051 K) - Thnx cooni
    Is there any other reported fixes for the S3 guys??
    I have read that some guys have a stutter above 5000RPM - I had that but after changing the plugs it was resolved - Cars running mapped software and WMI needs to change plugs every 10 000 Km... Depending on the Quality of the Plug IIRC
    Thank you in advance!
    Rgds
    BaDD Boi S3
    8P – Ibis White – Lamin-X’d – Custom 18” – Smash n Grab – Dropped Suspension - DRL
    Rain n Light – Cruise Control – Silk Napa RS4 Seats – Sunroof – PDC – LED Package - Auto Dip Mirror
    REVO Stage 2+ (All Bells n Whistles incl.) - DevilSown - CAI Kit
    Drag Wars Champion – 13.0s ¼ Mile
    215.3 wkw - 461Nm
    Acoustic Audio - Custom Sound Installation:
    Digital Designs 9515 – DD M3 Amp – Infinity KaPPa Splits – Optima – Batcap – Damplifier Pro – JVC DVD
