Results 1 to 8 of 8
    tdi-man's Avatar
    Jul 2009
    1,611
    leaking intercooler pipes
    just had to replace one of my bottom intercooler pipes due to metal part of if given up and noticed the other one has oil round the out side of it ...am i write in thinking if it's leaking oil it will be losing boost ?
    going to order a new one any way....
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Mar 2010
    Cleveland, North East
    214
    Yep, if they are passing oil it will be leaking pressure also, although probably not enough to notice any power loss.
    When I got my TDI I was surprised/horrified to see that Audi are still using the same stupid design that plagued the old A3 platform, I've worked on quite a few TDI Renaults and they never seem to suffer pipework failure, because the pipework is held together by clamps not daft spring clips.
    Mar 2008
    Bradford, WY
    788
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    S1MON A3's Avatar
    Aug 2010
    48
    there not any better realy and a waste of a 100 buck, they still use the crappy style clips.
    18" RS4 Wheels, EBC Grooved Disc, 45mm Lowering springs, R-Tech stage 1 Remap, EGR removed with map out, 187bhp 320ft lbs torque, Black grill , Westfalia detachable tow bar.
    Mar 2008
    Bradford, WY
    788
    Go for the ths intercooler and look at the pipes you get with that
    27,096
    TBH the leak you would get is so minimal it probably wouldnt make any difference to the boost unless you can feel it yourself, also most liquids can get through most gaps eventually no matter how small, just get some new seals for the joints as I did on mine, its prob just these need replacing, clean up the oil, job done, may also be advisable to get a catch can to keep as much oil out of the pipes as possible.
    S1MON A3's Avatar
    Aug 2010
    48
    TBH the leak you would get is so minimal it probably wouldnt make any difference to the boost unless you can feel it yourself, after most liquids can get through most gaps eventually no matter how small, just get some new seals for the joints as I did on mine, its prob just these need replacing, clean up the oil, job done, may also be advisable to get a catch can to keep as much oil out of the pipes as possible.
    Where did you get the new seals from ? Is it main dealer only?
    27,096
    Dealer
