Chris NottSky Insurance
Results 1 to 10 of 10
    May 2009
    131
    ESP button malfunction, maybe wire problem, someone post pic of connector?
    So I might of swapped the cables around on my esp button.
    Can anyone post a picture of the connector with the wires connected to it?
    I want to double check i have the correct wires in the correct hole.
    S3 MRU's Avatar
    Aug 2010
    Luton, Bedfordshire
    756
    Hey mate the connector for esp on mine is blue. and hazard is white. If your esp button is faulty i have one for sale. prefacelift version
    May 2009
    131
    OK looks like i made big mistake.
    I swapped pin 3 and 6 on accident. So I am wondering if my ABS module is bad now?
    Looks like 3 suppose to goto ground but it went to abs control module instead and 6 went to ground.
    May 2009
    131
    Quote Originally Posted by Russo2k5 View Post
    Thanks for the info but i guess i was not clear. I was looking for pin assignments on the ESP button but I got them.
    26,722
    Nah just get it round correct way & scan clear any errors, shouldnt cause a problem.
    May 2009
    131
    Thanks NHN!
    I'll scan it tonight
    Khufu's Avatar
    West coast of Scotland
    5,693
    I think it should be ok too. A lot of modules are are switchable earths anyhow.
    May 2009
    131
    I forget to mention that I turned the car on and pressed the esp button and the esp dash light did not light up.
    I'll check the vagcom tonight
    Khufu's Avatar
    5,693
    You could also check the 5amp fuse SC4 in case you have blown it by earthing pin 4 straight to earth.
    May 2009
    131
    i checked the fuse last night and it was indeed still good.
