Volks AutosEM Tuning
    Sep 2010
    Staffs
    33
    Slight Clutch Judder
    Guys,
    Anybody experienced this before when coming off the clutch I can feel a slight judder via the pedal, also sometimes when changing gear, there seems to be a slight thud when engaging the next gear ?
    Gary
    East Sussex
    617
    Clutch judder when pulling away is often related to a warped flywheel, plate, housing, seizing thrust bearing, or oil is getting on the clutch plate through a weeping oil seal, the oil generally means some slippage if excessive. If it is any of those you are pretty well looking at a complete new assembly at some point in the future. As for the thud, not sure dodgy gear changing too fast :P
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    sounds like a flywheel issue, very common
    Moved to the Darkside click below:
    Sep 2010
    Staffs
    33
    Cheers Guys, will get it checked out.
    Gaz.
