AH FabricationsJMB Retrofits
Results 1 to 8 of 8
    Dec 2009
    166
    Help from an expert please? maybe NHN Error code inside <3
    So unlike you guys here in the US, we don't get S3.... i wanted a ibis white and no dealers in my area had it in S-line so i bought it in Premium. After 2 years of owning the car i have bought a used S-line seats. First time i have swap the whole seat and i got an air bag light. So after a few months i decided to just swap the cushions and the cover out since the frames are the same. I wanted to use my original frame with original connectors. However, this hasn't fixed my problem. I checked to see if any wires are lose but found nothing... Here is the error code i'm getting, i've been driving it since then
    Saturday,17,April,2010,20:22:36:20331
    VCDS Version: Release 908.2
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Control Module Part Number: 8P0 959 655 A HW: 8P0 959 655 A
    Component and/or Version: Airbag 9.41 H13 4290
    Software Coding: 0032605
    Work Shop Code: WSC 06314 000 00000
    Additional Info: 8P0910339 BF-Gewichtsens. 001 0020
    Additional Info: Geraet 00000
    2 Faults Found:
    00591 - Seat Belt Switch; Driver (E24)
    007 - Short to Ground - MIL ON
    Freeze Frame:
    Fault Status: 11100111
    Fault Priority: 2
    Fault Frequency: 56
    Reset counter: 247
    Mileage: 61197 km
    Time Indication: 0
    Date: 2010.04.10
    Time: 16:43:55
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 2
    Fault Frequency: 52
    Reset counter: 31
    Mileage: 61197 km
    Time Indication: 0
    Date: 2010.04.10
    Time: 16:53:10
    PICS b/c u clicked thanks!
    Car is lowered now, i had to raise it up due to the fitment of the OZ futuras as i just got them. 18x8.5 ET45 front 18x9.5 ET 45 rear (Flushed to the fender)
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    you may have nipped a wire going from the bit the seatbelt clicks into mate
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    27,129
    Assuming you've tried to clear them 1st, but I'd say maybe these new seats didnt have the seat belt warning fitted????
    Easy way to check is if the seat belt buckle has any wiring going to them, if not thats the reason.
    I'd check all positions on the car loom side of connectors in the floor have a corresponding pin on the new seat connectors.
    As for expert, wouldnt go that far as many can help including Phil.
    May 2010
    2,502
    As for expert, wouldnt go that far as many can help incuding Phil.
    little harsh nige! i'd say phil was an expert ...
    2006 Phantom Black A3 2.0T S-Line.
    DSG | 18" BBS Pescaras | Rear Parking Sensors | MFSW | Symphony II | BOSE | Auto lights/wipers | Half leather
    MODS : '09 tail lights | TT vents | Weitec Hicon GTs | RNS-E 2010 | Controls Pack (Red Stitching)
    PLANS: Dumbos | 8P3 S-Line Rear Bumper | OEM Parking Sensors
    GONE BUT NOT FORGOTTEN:
    2005 Ebony Black A3 1.6 Sport tiptronic. You will be missed!
    1997 BMW 316i Coupe M-Sport. You won't be missed quite so much!
    27,129
    Whats harsh about that comment.
    May 2010
    2,502
    your implication that phil isn't an expert? nm lol
    27,129
    NO numnuts, I was referring to myself, read the thread title.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    haha like nige im hardly an expert (i got what you meant nige ) learning every day and once you start breaking things down they get less and less complicated, my dad i would call an expert not me though, cheers for the thoughts subby, as for the op id be taking niges advice first however as from the way i read your post youve kept the existing airbags buckles etc?, in which case its a fault clear and if not a nipped wire at a geuss
    Mods
