Results 1 to 18 of 18
    nealjohns's Avatar
    43
    REVO STAGE 1 = NEW CLUTCH?
    really want a stage 1 revo for my s3 but dont want to fork out for a new clutch and possibly flywheel..
    so my question is this...
    will the clutch definately need replacing or does it depend how i drive it etc..
    ie could i get away with the stock clutch
    i had a stage 1 im my old leon cupra r and everything was fine(except it couldnt handle the power with stock parts)
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,043
    I managed about 15K on stock clutch with REVO stage 1.
    Car hasnt had a hard life neither.
    Just had a new one fitted by AUDI on the very last day of warranty (long story/ pure fluke).
    Apparently, OEM clutches fitted to later cars and warranty replacements are stronger units as there are a number of reported standard S3s with failed clutches.
    Not a VAG strong point.
    AUDI deny this of course, forums suggest otherwise.
    That said, some are running Stage 2+ on OEM set up without any real problems.
    No definative answer really.
    Personally I wouldnt let it stop you, its a lottery, and a stage 1 map makes such a huge diffenece its worth the gamble.
    Good luck.
    Paul
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    Edinburgh
    211
    im running an s3 with mtm stage 2 upgrade around 330 bhp and still on oem clutch no problems .
    go for a map car is begging for it
    S3 SOLD
    Phantom Black S3 . MTM Stage 2 , Buckets , H&R , Milltek ......every Audi option.....................
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,781
    Not neccessarily...some cars and some clutches will do Ok with Stg 2,and some wont.
    Mine was Ok on Stg1,and as soon as the torque went up,that was the end of the OEM clutch.
    My advice would be to set some cash aside,just in case it gives in,and also to remember that if the clutch goes,the DMF will need replacing as well.
    Feb 2009
    60
    DMF doesn't necessarily need replacing as part of a clutch upgrade - my ed30 is a little over 360bhp and the DMF was perfectly fine when I upgraded to a Helix clutch.
    Quote Originally Posted by S3Alex View Post
    Oct 2009
    Aberdeenshire
    192
    My S3 has done 12k miles on the standard clutch and has been stage 2+ for around 10K miles. No clutch slip yet and the car is driven quite hard.
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,043
    Quote Originally Posted by robern2 View Post
    Same here.
    If you replace in early enough the DMF will be ok.
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    DeckedS3's Avatar
    Apr 2008
    South East
    550
    I had no issues with stage 1, it was stage 2+ that killed it!
    Meteor S3, APR Stage 3, APR HPFP, Milltek TBE, LOBA/Sach's Clutch, Bilstein PSS10's, H&R ARB, Gen4 Haldex PP, EVOM's DV & CAI, Forge TB with Pro-Alloy IC, BBS CK 19" My S3
    JamesS4cab's Avatar
    Mar 2008
    1,091
    Stage 2 not driven overly hard - 24k on current clutch - been on Revo for 4k miles.
    No dramas.
    Best 499 I ever spent!!
    DO IT.
    "Dont get me wrong. Ugly girls need loving. Just not by me."
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,146
    So taking into consideration the 'potential' risks of melting your clutch, I guess a revo stage 1 is not a wise move/risk for DSG equipped cars?
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    DSG box can handle 380/90 lb ft no problem
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,146
    Quote Originally Posted by akash_sky1 View Post
    What's your source?
    What can a manual clutch handle?
    akash_sky1's Avatar
    1,209
    Just from seeing what many others with DSG are pushing out with no reported problems after several thousand miles, from spending far too much on VAG tuning forums. Some companies are offering uprated DSG clutch packs that can handle over 400 lbft safely now.
    Standard clutch is a bit of a lottery, if its a fresh one and not one of ones seemingly made of chocolate then seems to be about 340 ish but only for a few thousand miles before they give up the ghost, and also depends on your driving style. DSG seems to be a safer bet TBH for tuning on if you dont want to replace the clutch on stage 2+.
    East Sussex
    617
    How long any clutch lasts whether it be stock, stage 1 etc. really is all down to how it is driven, and how often you are pulling away as fast as you can every time, or going for it in 2nd,3rd, clearly the higher the stage the shorter the time the parts will last again with how you drive it.
    I think Stage 1 should be fine if you are not flooring it every set of lights and roundabout etc.
    NICK-C's Avatar
    Nick
    Dec 2009
    Derbyshire
    437
    Interesting read guys, I am hoping to go stage 1 soon so hope the standard clutch will be OK.
    Now - On the hunt for a new Audi!
    Gone - A5 Sportback S-line 3.0TDi quattro s-tronic
    Sadly gone - Ibis White S3 Sportback Black Edition
    Previous:
    '57 - Astra Sri Sport Hatch
    '95 - Celica GT4
    '54 - Astra Coupe Turbo
    '51 - Astra Sxi
    nealjohns's Avatar
    43
    cheers for the input guys...
    think thats put my mind at rest..
    like you say,paul,its a bit of a gamble on whether it will hold but you think the stage 1 is clearly worth it..
    bugger now i got to find 500 quid :-/
    mrs wont be impressed.it'll be coming out of her xmas present fund...
    East Sussex
    617
    Yes Stage one is by far the best value, and worth every penny
    nealjohns's Avatar
    43
    yeh sounds like its worth the money..
    altho just seen the other new thread about the clutch judder and that its connected to the dmf possibly. im sure mine does that a tiny bit.always thought it was normal tho..
