Badger5JMB Retrofits
Results 1 to 11 of 11
    synthdood's Avatar
    Oct 2004
    Amsterdam, Netherlands
    286
    Unhappy `left dipped headlight` but bulb and fuse are okay
    My 2005 A3 8p with normal halogen bulbs has the left headlight not working since today. The DIS shows the `left dipped headlight` error. When I went to replace the bulb I dicovered that there was nothing wrong with it. I checked the fuse and that is also okay. I tried disabling the cold diagnosis with VAGCOM thinking that maybe a faulty measurement that was causing the problem, but unfortunately that didn´t help.
    Is there anything else I can look at besides bulb and fuse? Maybe a relais?
    A3 sportback 2.0FSI sport, mauritius blue, proline, alu, interior light pack, rain&light sensor, cruise.
    Fossie
    Rhubarb Triangle
    3,969
    Have you done a full fault scan to see what that says ?
    How do you know there is nothing wrong with the bub ? Did you try substituting it in the other side ?
    Finally, if you have any test equipment try and see if there is the correct voltage present on the bulb connector.
    Just because a bulb looks ok does not mean it is ok !
    synthdood's Avatar
    Oct 2004
    286
    The VAGCOM fault scan says that there is an open connection or a short on the left headlight.
    I replaced the bulb with a new one (that I measured so I know for a fact the new one is okay) but that didn't help. I measured the voltage on the bulb, that was 0.3V (I am guessing this is the measuring voltage of the colld diagnosis system). There is 12V on both sides of the fuse so I know the fuse is okay. It looks as if the voltage from the fuse is never reaching the headlights. Just to be sure I also switched the fuses for the left and right headlight. That didn't help.
    Aug 2010
    teesside
    109
    hi mate i had this problem a few weeks ago with a customers car, same fault as you and i tried everything to get it working with vagcom and a very clued up mate on audi's and vw's, i ended up taking it to audi and it was the lighting control unit!! they are a common problem on the 8p apparently, the bad news is that it cost around Ł450 to get it fixed!!!
    Fossie
    Rhubarb Triangle
    3,969
    Sometimes the ecu's get locked up like any other computer.
    Might be worth disconnecting the battery for half an hour or so to see if it resets itself. As far as a 'common problem on A3's ' is concerned I haven't seen any other threads on here about the problem.
    Do a search on here to see if there is anything about it.
    Sorry can't be more help
    Good luck
    synthdood's Avatar
    Oct 2004
    286
    I seen very similar problems pop up many times in US forums but those always appear to occur with xenons. In fact a class action lawsuit is being filed against audi for those cases because eventhough Audi are aware of the recurring issue they keep charging customers for (very expensive!) repairs where they completely replace the HIDs and these repairs do not appear fix the problem.
    I don't have xenon though, just the normal H7 halogens. I think I will take the car to audi next week and see what they come up with. Let's hope it is not going to be expensive.
    synthdood's Avatar
    Oct 2004
    286
    So I took the car to Audi this morning. They changed the bulb and all was fine. You have no idea how stupid I feel right now (I have a degree in electronics for f** sake).
    The question remains, why was there no 12V when I measured in the first place? And why didn't it work when I replaced the bulb? The only thing I can think of is that I should have switched the car off and on after replacing the bulb. I tried replacing it while the lights were switched on in order to see if the new bulb worked. Maybe the car refuses to supply 12V after sensing something is wrong and it needs a restart? Lesson learned for next time: Replace bulb while the car is off and test afterward!
    Fossie
    Rhubarb Triangle
    3,969
    - sometimes we can't see the wood for trees !!
    Glad you got it sorted.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    Quote Originally Posted by synthdood View Post
    when the can line sees what it percieves to be no bulb it shuts off power to the line
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    27,114
    Nah I reckon it just wanted to wind you up on that day for not being nice to it, A3's need some love & attention you know, a gentle rush of the dash with care & love does the trick lmfao
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    haha nige is soo right treating the a3 mean doesnt keep it keen!
    Mods
