Chris NottSky Insurance
Results 1 to 9 of 9
    marlowA3's Avatar
    Doncaster, South Yorkshire
    93
    Traction control light on help??
    Traction control light is on all the time, when i had car serviced Audi said its to do with brake pressure or summat, if it needed doing it would be Ł900 which i was like there trying to sting me.
    It aint affecting the car apart from wheelspin with the TC not working.
    Does anyone have any idea what it could be or how to solve it etc any help would be appreciated
    Mark
    BASS 666's Avatar
    BMW aye right dead on..
    Sep 2010
    belfast
    463
    just a thought mate. my brake lights stopped working a while ago and it was the switch. when the switch went it brought my tc light on. the thing is i dont know if my tc was off when my tc light was on anyway i changed the switch and the tc light went off. hope this helps.
    2002 1.9 tdi 130ish brake a4. full reiger body kit, 19 inch rs6 avant rims, eibach springs, home made grill, full leather interior, centre arm rest, quad powerflow exausts, a few engine mods, chrome door mirrors, aero wipers, s line door blades.
    edition's Avatar
    Nov 2007
    1,417
    Is it a 3.2?
    For Sale :Set of Black Rear carpet Mats P.M. for a Price
    Jan 2009
    27
    Quote Originally Posted by marlowA3 View Post
    Mark
    This is correct, if it is the brake pressure sensor then it is a very expensive job. The ESP light stays on continiously and nothing happens if you press the switch on the dash. Since the brake pressure sensor has been intergrated into the ABS pump you have to replace the ABS pump which is expensive. You could try a refurbished pump perhaps, roughly Ł350 or so, then you need to get it fitted, brakes bled etc & get it all coded up again.
    marlowA3's Avatar
    93
    Yeah thats what they said at Audi they wanted Ł900 from them tho!
    is this somethhing i need doing asap or can it wait etc?
    Apr 2010
    St Helens
    310
    i had the same problem but rarther than pay audi prices of Ł800 upwards + vat i used some one called BBA reman. they re-condition your pump for aroudn Ł400 and alls you have to do is re-ft the pump and code it to the car and your good to go brake pressure sensor is the sensor in the ABS pump... common fault on a3/golf
    marlowA3's Avatar
    93
    I just seem to be getting all the common faults on my car dam!
    I'm gonna see if warrantys cover this.
    Aug 2010
    1,540
    yeah warranty will cover it. ive seen a few on a3/golf/touran. read the actual value for the fluid pressure on vagcom... bet it says 190 odd bar without you even pressing the pedal.
    get a recon pump for it??
    Apr 2010
    St Helens
    310
    re-condition far cheaper than a new unit and much easier plus you also get warranty with them that is what u did
