EM TuningAH Fabrications
Results 1 to 12 of 12
    ~RS~'s Avatar
    Feb 2009
    1,463
    Anybody fitted a S line spoiler (NOT VOTEX) to a Sport spec Sportback?
    I got a S line spoiler from ebay for a bargain compared to what Audi are charging for them, then cut the lugs off for it to get prepped n painted.
    Before taking it to get sprayed I put the spoiler on tailgate just to see how it would look, I noticed that there was a small gap of a few mm max between where the spoiler would sit and where the brake light built into the tailgate is even when the spoiler was pressed down tightly and the spoiler isn't bent or warped at all. This brake light would be removed as the sportback S line spoiler has a brake light built into it which will be rewired into old ones connection. When removed though it would leave a gap open to the elements
    A search here on the subject revealed that when buying a new S line sportback spoiler from Audi they supply some sealing for over the old break light gap? Sounded odd as it not supposed top be fitted on non sportback.
    If you have ETKA would u be a diamond and post a pic of the S line spoiler for a sportback so I can see if it comes with this seal for the brake light hole left in tailgate.
    Anybody who has fitted a genuine S line spoiler (not votex) on a sport ed sportback how did you sort this out?
    Dean's A3's Avatar
    TDI S3 Hybrid
    May 2010
    261
    I'm pretty sure S-line and S3 spoilers are similar, (but don't quote me on that) I did have votex on my SB before I did my facelift then changed it to S-line/S3 one. (see my facelift thread) Yes there is a sealing unit that goes around the brake light, when I bought mine it came with it though I don't have the part number..
    ~RS~'s Avatar
    Feb 2009
    1,463
    Aha! Thanks Dean, forgot about your S3/ S line spoiler. So that's the bit I need, what's the bet that they do not sell it separately! Bugger!!
    Can you notice the gap when it has the sealing unit in it? Or does it blend in well? Can the sealing unit be fabricated using something else? What is it made of?
    If you get a min a close up pic of the section were speaking about would be cool mate. Understand if your a lil busy though mate.
    scottie123's Avatar
    Oct 2008
    1,888
    The sline and s3 spoiler are exactly the same. When I fitted mine, there was a small gap as you mention, but didnt cause a problem as the small gasket supplied sealed it fine. I have had no problems for about 6 months now, 'touch wood'
    All the gasket was made of iirc was sticky backed (one side only ) foam . Should be a piece of piddle to source, And probably only peanuts in cost.
    05 SB SE BKD
    Build Thread
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,403
    I fitted the S3 spoiler onto the back of my Sportback but i didnt notice any gaps.... anyway here are some pics along with the thread i had made ages ago...
    Sportback spoiler fitting
    Ash
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    ~RS~'s Avatar
    Feb 2009
    1,463
    Cheers guys...
    I was following the instructions for a 3dr not realizing the 3dr spoiler doesnt have the middle lug so I cut that one of too Ah well sure the sickaflex or similar will hold it down well.
    Thanks for the info regarding the foam as well, I will have a look about for that scottie. Did you cut off the middle lug?
    10itwasntme187 yours looks nice on, cant wait to have mine prepped, sprayed and fitted now... Really makes a huge difference! Cheers for the link to the thread seems you got yours to fit nicely, so are you saying that your spoiler actually sit over the hole left by removing the original tailgate brake light? Or did you also get a foam seal?
    BTW if any of you guys could get a close up pic of under the rear brake light I'd really appreciate it.
    ~RS~'s Avatar
    Feb 2009
    1,463
    The spoiler pre- prep/spray:
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,403
    Quote Originally Posted by ~RS~ View Post
    Cheers guys...
    Yes once the brake light has been taken off you have a hole where the middle leg goes in (No dirty jokes boys).
    You can tighten in the middle leg which will hold the spoiler down into place.
    The way i did it was to clean the car so no dirt gets in the way of the body glue, and remove the old brake light. then prep the spoiler by putting the body glue around all the egdes of the spoiler, set it into place with the middle screw into the gap left from the old spoiler and tighten up the screw to hold the spoiler down. finally make sure no extra body glue has squeezed out onto the car and tape the spoiler down with masking tape so that it doesn't move overnight.
    next day remove the masking tape and polish off for result. doesn't take long at all to do... lucky for me the spoiler was already painted to my car colour so i just fitted it on
    also from those pics i see you have the remains of the double sided sticky that was used when it was first fitted... i scraped them off with a screwdriver as it sat a bit wonky on the tailgate and then applied the sikaflex to that same area....
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    ~RS~'s Avatar
    Feb 2009
    1,463
    Thanks for the instructions mate, the shop that's spraying it will also fix it down. He tells me there is some rubber thing that removes the old double sided tape completely.
    I've already cut the middle lug off! Castrated it lol... You can probably see where it used to be in the pics. Hope this isn't a deal breaker as you said you used it to screw spoiler down to car, I don't think I can glue it back on it either.
    If you get a min and wouldn't mind taking a close up of under the rear brake light I'd really appreciate it mate, just wanna show it to the garage so they know how it should look like, as he was a bit unsure about the gap.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,403
    Il try and get some pics for you tomorrow
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,403
    here are the pics for the benifit of anyone looking through this thread... Rich you already have a pm with the pics.
    yes the car is very dirty thanks to the crappy rain this week!
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    ~RS~'s Avatar
    Feb 2009
    1,463
    Cheer mate
