    Nov 2010
    2.0 TDI Temp sensor change, help needed please
    Hi I've had my 2006 2.0 tdi A3 SB S-LINE for 2 weeks now and it would seem i have a warm starting problem. i have read that this can be cured by fitting a fresh startermotor but before i take the plunge i'm going to try the water temp sender first.
    Could someone please tell me where its located and if i need to remove anything to make the job easier? the more instructions the better!
    thanks
    Tom
    Mar 2008
    Bradford, WY
    788
    Run it on vag-com first see if theres any faults, but temp sensor is changed when engine is cold
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    Nov 2010
    Thanks for your reply, it seems that warm start issues are normally coolant temp sender or battery/starter related! i've bought the temp sender allready so i might aswell fit it and then go down the vag-com route before i splash out on the starter.
    can anyone give me a rough description on replacing the temp sender!
    thanks
    27,126
    If you have a BKD engine, then there are 2 temp senders, 1 is on the right side of the engine just above a thin turbo oil feed pipe, other is at the front of the emngine in a crap position behind the intake manifold flap.
