EM TuningVolks Autos
Results 1 to 8 of 8
    rickyquicky's Avatar
    Dec 2008
    London
    340
    Tdi noises under the bonnet??
    I was listening to my car earlier whilst parked up idling, and after kneeling down on the pavement to listen further down under the engine I could hear a very faint intermittent whirring/grinding noise.
    The noise is quite faint, and only comes every 10 seconds or so and lasts for a second or so, the rest of the time there are no noises and it all sounds sweet.
    Any ideas what this could be? A drive belt pulley? Tensioner? DMF?
    Mar 2008
    Bradford, WY
    788
    Tensioner, get it replace for 30 before alternator siezes
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    Dec 2008
    London
    340
    Thanks mate, any way to test first?
    26,773
    Yeah, stick a new one on & see if it goes :P
    Mar 2008
    Bradford, WY
    788
    Quote Originally Posted by rickyquicky View Post
    Not really, mine was squeeky, took it to audi who fobbed me off and said its self adjusting. A year later car stalled on a roundabout with a siezed alternator.
    S1MON A3's Avatar
    Aug 2010
    48
    Quote Originally Posted by navnayyar View Post
    To be far though it did last another year lol. Maybe if you checked it after 6 months and you were still unsure then you should have got it changed.
    Mar 2008
    Bradford, WY
    788
    Quote Originally Posted by S1MON A3 View Post
    Was too busy buying mods but caught up on me eventually
    ~RS~'s Avatar
    Feb 2009
    1,463
    My tensioner pulley broke leading the ribbed belt to wrap around bottom of crankshaft pulley. Shredded belt came into contact with the cambelt and bottom sprocket causing camshaft timing to be incorrect... This also lead to pistons coming together with valves and bunch of other major PITA's... Long story short new engine required and corresponding parts! All, thankfully covered under warranty! Otherwise 6K out of pocket
    I'd get that seen to asap if I were you mate
