Volks AutosMonster Motorsport
Results 1 to 17 of 17
    Banana Armour
    Aug 2009
    Leicestershire/Oxfordshire
    171
    Visit aterro's Instagram Channel
    2.0 tdi a3 140. What head can I use? Nd list of parts.
    Got a a3 tdi 2.0 sport 140
    Bkd engine I think.
    Needs new head. Suffix a I've got
    Wa other heads fit? Eg Ibiza ones? 1.9?
    Wen changing heads could you list all parts I need?? Cheers
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    Banana Armour
    Aug 2009
    171
    What suffix head is that???
    Could you also list all the new parts needed??
    Banana Armour
    Aug 2009
    171
    Bumpp!!!
    Fossie
    Rhubarb Triangle
    3,968
    Surely it can't be reasonable to expect anyone to list out the miriad of parts necessary to fit a new head ?
    There must be hundreds !
    Feb 2007
    1,257
    To swop the head over you need a head gasket, head bolts,cam bolts and injector bolts. The head i have advertised is a 03G 103 373 A . If you click on the following link for SCN where the classified section actually works you can see pictures etc.Standard PD140 BKD head. - SEAT Cupra.net - SEAT Forum
    Banana Armour
    Aug 2009
    171
    Don't want another suffix a head as all of them crack according to research.
    Will any other heads fit? Eg the pd150? Or pd140?
    Banana Armour
    Aug 2009
    171
    Feb 2007
    1,257
    The BKD engine is a PD140. The only other head to fit a BKD PD140 engine is the PD170 head but you need to remove the cams as they are different. Not all A suffix heads cracked and 150 for a pressure tested head compared to 800 + for a new one.
    Banana Armour
    Aug 2009
    171
    What is the difference between suffix a b nd c heads??
    Fossie
    Rhubarb Triangle
    3,968
    Quite a few 'a' heads cracked
    Very few 'b' heads cracked
    No 'c' heads cracked (yet)
    If devonmikeyboy is selling a pressure tested head it doesn't matter what suffix it has, it'll be ok.
    And if it isn't I'm sure he'll sort it.
    Feb 2007
    1,257
    03G 103 373 C suffix is stamped on both the late PD140 heads and the PD170 heads as they are both designed and made the same way.
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,966
    Quote Originally Posted by devonmikeyboy View Post
    Any ideas where exactly it is stamped ...pics ? any other ways to tell ?
    Full leather/19"wheels/cruise/
    Fossie
    Rhubarb Triangle
    3,968
    As you look from the front of the car - right hand side of the engine underneath the fuel pipes.
    Obviously you have to remove the cover first !
    Feb 2007
    1,257
    The picture below shows what the 03G 103 373 stamp looks like on the head.
    Banana Armour
    Aug 2009
    171
    so the pd140 heads are the same as pd170 par cams?
    what is the suffix a heads made out of incomparision for the suffix C heads?
    Feb 2007
    1,257
    Both PD140 and PD170 heads are stamped 03G 103 373C
