Sky InsuranceChris Nott
Results 1 to 12 of 12
    palexr's Avatar
    Aug 2005
    uk
    64
    Remapping via OBD is possible on new A3s - MY11 1.8TFSI
    A little while ago I posted a thread titled "Remapping via OBD not possible on new A3..." This thread is just to correct that, they can be remapped via the OBD.
    I recently investigated using a Bluefin device on my new MY11 1.8tfsi but was told by a couple of dealers and Superchips themselves that it most probably wouldn't be possible because of the anti-tamper code on the new ECUs. This meant that the only way to remap was to remove the ECU.
    The advice on this forum was the same, the new MED17.5 ECU could not be remapped directly via the OBD and the ECU would have to come out. However, a few suggested that GIAC and REVO had solved this issue. Looking at REVO's website there is a news announcement that they have got round the security code. So I took the plunge and went down to AMDEssex at Lakeside, a very helpful and friendly bunch of people. They quickly reassured me that it would be possible.
    So, one Stage 1 remap later and I've got a new car. The remap has definitely worked. Straight off their premises and the difference was noticeable . Power delivery is much more immediate and the smile I had overtaking is now a grin.
    Before
    Power: 171.3 bhp (supposed to be 157, a bit of a Audi freebie Brucey bonus)
    Torque: 184.4 lb/ft @ 4693 rpm
    After Remap
    Power: 214.2 bhp
    Torque: 261.1 lb/ft @ 3171 rpm
    Happy days.
    Sorry for the double post/bump on this but I thought it was worth sharing in its own post. I know this is nothing new for 90% of you Audi veterans but I thought it would be useful for newbies to know that it is possible to remap new MY11 models (at least REVO can do new 1.8TFSIs).
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    knew it was possible but now most the other moneys do too glad youre happy with it
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    palexr's Avatar
    Aug 2005
    uk
    64
    The other moneys? Who are they...
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    monkeys*
    Mods
    I'mRonBurgundy?'s Avatar
    Lets make that kitten purr...
    543
    Can you give an idea of cost?
    2008 A3 1.8T FSI S-line Phantom Black, Bose, iPod Dock, Front Centre Armrest, Storage Pack, Aluminium Pedals, H&R Spacers, Eibach Pro's, Ambient Lighting, Pressed plates with Ingolstadt surrounds.
    palexr's Avatar
    Aug 2005
    uk
    64
    Yep, AMDEssex charged me 449 + VAT (527) for the REVO map. This is a bit more than the average, but there a few reasons I went with them. They (AMD and REVO) seem to be highly regarded on the net. Seems you do get what you pay for. The REVO map gives a slightly higher change in terms of before and after than say Bluefin, on our cars anyway. As I said in the first post there seems to be lot doubt whether or not our cars can be Bluefined. AMD are only 40 minutes away.
    Well worth it if you ask me. The car feels completely different, in a good way.
    This is the printout of the rolling road results.
    Jul 2009
    56
    In fairness this is nothing new, you still need to remove the ECU first to bypass the code, from then on you can use the OBD port to change files. I am pretty sure Superchips offer this, i.e. they remove the ECU, do the needed changes, replace it, then the OBD can be used. I don;t like the idea of the ECU being removed, hopefully someone will crack the code problem and the ECU can be left in place.
    Jul 2009
    56
    here's a link to the Revo solution showing the need to remove the ECU.
    Introducing Revo SPX and Crypt-X software at JKM! - SEAT Cupra.net - SEAT Forum
    palexr's Avatar
    Aug 2005
    uk
    64
    OK, thanks. It is confusing for people new to this. Although it does also say "there is no tell tale sign to if a car has antitune software present or not, Cars can have the same ECU number and software version but some will have the lock out and others not so". I asked AmDEssex to check and mine could be done directly.
    Jul 2009
    56
    basically as i understand it, its the same ECU and some have the security present and others not, if it is present the ECU has to be removed and opened, my worry with this is that i am pretty sure they use ant-tamper screws, paper seals, etc etc so can tell if the ECU has been opened. Also i heard that in theory, as the security is software based, manufacturers could add the security software to cars which did not have it from the factory during a routine software update !.
    Hopefully someone will be able to solve the problem and OBD will work on all cars without ECU removal, i really don't like the idea of the ECU being opened.
    palexr's Avatar
    Aug 2005
    uk
    64
    Yes, it is a minefield. Not sure why they are going to such lengths to lock down their cars. Probably just generic corporate paranoia.
    Like i said, I asked AmDEssex to do it via the OBD port, it would be just my luck if there was some kind of "misunderstanding" and they did it the other way. Any way of checking easily?
    A further question, I'm guessing (hoping) the OEM components are good for 215bhp/260lb? The posts I read here appeared to say that the were good for a stage 1 remap.
    ~RS~'s Avatar
    Feb 2009
    1,463
    Any update on how the map was put on mate? Did they remove the ECU after all?
