Sky InsuranceVolks Autos
Results 1 to 8 of 8
    munchkincoupe's Avatar
    Aug 2010
    971
    OEM Dampers - same between all 8P models?
    Are the dampers the same between all of the 8P model A3 3 door/ 5 door variants?
    I'm going to fit H&R 50mm springs at my 2004 3 dr A3 2.0 TDI on 35k miles. Not really got the cash to go for uprated dampers too. So I thought if someone is upgrading to full suspension/coilovers then I may get lucky and get some low mileage OEM dampers and get them fitted at the same time as the springs. Obviously need to know which model A3 variants share the same dampers to know if I can do a successful transplant - part numbers would be a great help too
    Also going to change top mount rubbers to upgrade so if someone can recommend a brand too that would be great
    Thanks for your help
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    -50mm springs might be pushing it on standard shocks. I'm pretty sure the shocks between the SE and Sport will be different. Possibly between the Sport and S-Line also.
    The oem ones are shyt anyway so just change the shocks when you can afford some aftermarket Bilstein or Konis etc.
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    as said there is a difference between the se , sport and the s-line , the s-line ones are over engineered so are the best ones of the lot
    ​She is back on the road yay!!
    Oct 2008
    Telford
    2,488
    Quote Originally Posted by fnmrst View Post
    Dont think there is mate, I was told they are all the same. Could have been told rubbish though!
    B6 1.8T Avant s line gmbh
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    im sure they are different otherwise how do you explain the differnce in handling and ride comfort , the springs alone wouldnt do this
    Sep 2009
    Finland
    39
    Springs + swaybars.
    Specially swaybars can change car handling alot.
    A3 8P Sportback 1.9TDIe DPF 77kW. Chip tuned. 105kW / 336Nm. Eibach Sportline suspension. InterAction B9 18" summer wheels.
    Aug 2010
    971
    Stoke Audi have confirmed that dampers are different between 8P models here http://www.audi-sport.net/vb/stoke-a...ml#post1102524
    So should be fair to presume that the lower ride height cars should have the dampers best suited to lower springs
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    thats what i thought i had a funny feeling that they were all different depenent on model / engine size etc...
