Badger5Sky Insurance
Results 1 to 9 of 9
    rickyquicky's Avatar
    Dec 2008
    London
    340
    10k boost diesel
    Has anyone used this? I bought a can today to use it tomorrow morning...it says the best place is to spray it directly into turbo intake.
    Whats the easiest way to get to the turbo intake? From the top or bottom of the engine bay?? Or is spraying it into the air intake (after MAF) just as good?
    BASS 666's Avatar
    BMW aye right dead on..
    Sep 2010
    belfast
    463
    what does the spray do ?
    2002 1.9 tdi 130ish brake a4. full reiger body kit, 19 inch rs6 avant rims, eibach springs, home made grill, full leather interior, centre arm rest, quad powerflow exausts, a few engine mods, chrome door mirrors, aero wipers, s line door blades.
    Dec 2008
    London
    340
    Sorry, I should have said lol.
    Its an engine 'cleaner'/de-coke, but rather than the usual 'add to a tank of fuel' its a spray that goes into the intake and seems to have reasonable reviews.
    BASS 666's Avatar
    Sep 2010
    belfast
    463
    oh right. i would take the big pipe off the airbox or open the airbox and do it that way mate.
    Mar 2008
    Bradford, WY
    788
    I wouldnt spray it in the airbox or anywhere before the maf sensor. Remove the airbox and spray it in the pipe just after the maf sensor. But this seems bit pointless as most of it wont even get to the engine. Will stay in the pipes especially the intercooler
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    Jul 2007
    London
    3,255
    I would not spray that **** at all into a diesel engine as you can easily hydrolock the engine + whatever rubbish it will dislodge it will go inside the engine ! I've done-it once to a ford fiesta van and had to replace the engine as it started blowing blue smoke afterwards ! Never again. If you want, take the inlet manifold off and clean the crud OFF the car and block the EGR valve !
    FOR SALE:
    BASS 666's Avatar
    Sep 2010
    belfast
    463
    thats why i asked what the spray does cause i dont believe in all that stuff. i took my inlet manifold off and decoked it then blocked the egr valve off. theres nothing like knowing that you did the job right..
    Jul 2007
    London
    3,255
    What it will do is bend the rods ! You will have the same result if starting the car on easy start/ether or brake cleaner. The vapours will ignite at the wrong time and will break rings and bend rods. If you wanna see what liquids do to diesel engines do take the inlet manifold off and spray water with a window cleaner type of spray, you will love the detonation and thats just a few droplets ! Imagine all that foam getting into a high compression engine and all the hard carbon dislodged will go into the intake jamming your inlet/exhaust valves open ! This stuff should be banned, really !
    FOR SALE:
    Dec 2008
    London
    340
    Fair enough, i'd heard some positive things about it, and I used it all this morning - before I read about the possibility of engine damage lol!
    Anyway, used it before a 110 mile journey back home this afternoon, you rev the engine to 2500rpm and then blast it in the intake. The car got me home which is a good start haha!
