Badger5Chris Nott
    TAC
    TAC's Avatar
    3.2 V6 Burble... hmmmmmmm
    Oct 2009
    302
    HELP needed, Fitted cruise control no can't get it to work?????
    Hi, right follwed the retro fit guid from the site thanks pns2007 very helpfull got it in and managed to clear most faults and now cant get it working below is the vag com coding faults brought up and I have tried initialising it to no avail!!
    Readiness: 0110 1101
    VAG-COM Version: Release 704.1
    Data version: 20070422
    Friday,29,October,2010,12:26:26:26365
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 22 25 37 42 44 46 52 56 77
    VIN: WAUZZZ8P76A150271
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: 022-906-032-BDB.LBL
    Part No SW: 022 906 032 HQ HW:
    Component: MOTRONIC ME7.1.1G 7789
    Coding: 0000178
    Shop #: WSC 06314
    1 Fault Found:
    001384 - Cruise Control Switch (E45): Implausible Signal
    P0568 - 002 - Lower Limit Exceeded
    Address 02: Auto Trans Labels: 02E-300-0xx.LBL
    Part No SW: 02E 300 047 F HW: 02E 927 770 AE
    Component: GSG DSG 070 1122
    Coding: 0000020
    Shop #: WSC 06314
    No fault code found.
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.LBL
    Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
    Component: ESP 4MOTION MK60 0102
    Coding: 0021128
    Shop #: WSC 06314
    Any help and advice would be greatly recieved
    Tom
    Current - A3 3.2 DSG S-Line
    Gone but not forgotten Honda S2000 GT K&N FPIK (F***ing lairy in the wet but so so much fun...)- Golf MK3 GTI 16v -Mondeo V6 24v
    FOR SALE - Indicator stalk and lower steering wheel cowling
    A3 3DR pair of rear lights in A1 condition from my 06 A3
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Hi Tom
    As you have a steering wheel code fault have you recoded the wheel to know the controller has cruise ie here ...?
    Control Module Coding
    Select 16 (Steering Wheel Electronics)
    Coding -> Function 07
    00?xxxx: Transmission
    0 - Manual Transmission
    1 - Automatic Transmission
    00x?xxx: Steering Wheel
    0 - 3-Spoke, w/o Tiptronic, w/o Multi-Function
    1 - 3-Spoke, with Tiptronic, w/o Multi-Function
    2 - 4-Spoke Multi-Function (with Radio Control)
    3 - 4-Spoke Multi-Function (with Radio/Telephone Control)
    4 - 4-Spoke Multi-Function (with Radio/Telephone/Voice Control)
    00xx?xx: Tiptronic/Heating
    +1 - Tiptronic on Steering Wheel
    +2 - Steering Wheel Heating
    00xxx?x: Cruise Control/Board Computer
    0 - no Board Computer, no Cruise Control
    1 - Board Computer, no Cruise Control
    2 - no Board Computer, Cruise Control
    4 - Board Computer, Cruise Control
    00xxxx?: Rear Wiper
    0 - w/o Rear Wiper
    TAC
    TAC's Avatar
    Oct 2009
    302
    Quote Originally Posted by paddy View Post
    Hi Tom
    00xxxx?: Rear Wiper
    0 - w/o Rear Wiper
    Am a complete novice at coding so the code i need to enter as I have a mfsw with tiptronic is 0014140 am i correct?
    Cheers Tom
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    sorry i have cut the list short so it should have 1 on the end for rear wiper...but yes, check your code as it is now and change your second to last number too 4 ie 0014141 I think.
    always make a note of the original code so you can change back if it all goes wrong.
    TAC
    TAC's Avatar
    Oct 2009
    302
    Paddy your a star cheer mate all working perfectly on the cruise control front however have disturbed something which is now feeding back White noise through the rnse and speakers doh.......
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    That code you put (4) in is for telephone /voice control on the steering wheel ? maybe it needs to be (2) ie MF with radio...not sure of your set up ?
