Sky InsuranceJMB Retrofits
Results 1 to 8 of 8
    Mar 2010
    42
    Lowering Springs Fitting Guide
    Hi Chaps,
    Just got some H+R springs and spacers from DPM, going to do the work my self, is there a howto guide floating around anywhere? Or if not is there anything special I should know?
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    i wouldnt have thought they would be that hard to do i did some on my old ford and they were easy
    ​She is back on the road yay!!
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    Fronts are big enough job mate iirc, I just left it to the pros wasn't expensive
    Moved to the Darkside click below:
    Mar 2010
    42
    Got a friend that's a mechanic so might call on his help, be just handy if there was a guide floating around on the net somewhere but it appears not.
    S1MON A3's Avatar
    Aug 2010
    48
    Best bet is to just crack on a have a go, its easy. The rear is just 1 bolts and job done, the front are a little more tricky but still easy.
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    i took front driveshafts out the hubs and did it that way.......not a very bad job at all imo.OH and i replaced the top mounts ...worth doing that,cuz if its knocking at the front......its same job again!
    Full leather/19"wheels/cruise/
    col6821's Avatar
    Feb 2006
    Warwickshire
    175
    Agree with above, the rears are easy, just remove the one bolt to drop the lower arm down and remove the spring, replace and jack the lower arm back up to put the bolt back in. I removed the outer bolt, as the inner bolt has the offset washer for camber adjustment on it (I have a quattro, so not sure if this apples to 2wd as well). Also, if you have xennons, be careful to make sure that the headlamp levelling sensor goes back with the arm in the right direction so that it can still move up and down. I missed this when raising the lower arm and managed to get the sensor arm stuck the wrong way round, cost me 30 at a local independent when the headlights wouldn't raise up!
    The fronts were a bit of a 'mare to be honest, you need a BIG mallet to knock the hub assembly off the bottom of the damper, and there's not much room to manouver the damper out of the wheel arch, I managed to pull one drive shaft out by accident (it would have been quicker and easier to remove this first) which then meant removing the under tray from the engine and replacing the grease and circlip from the shaft (which was remarkably easy).
    As you can probably tell, I'm no mechanic... Still one wheel alignment and headlamp diagnostic check later all is well.
    Col
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    better to take off complete hub with damper on the front,alot easier than trying to take damper off hub assembly,then after a couple of days get the alignment checked.
