Sky InsuranceEM Tuning
Results 1 to 13 of 13
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    rear bulbs blowing
    hi all just a quicky my car for a little while has been blowing rear bulbs every few weeks i know that bulbs go but they seam to be going a bit too often anybody had a similar problem to this the good thing is i dont have to pay for bulbs as i can get them in work but its still annoying to have to change bulbs all the time any ideas
    ​She is back on the road yay!!
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    have you put a multimeter on it to check for surges its the only thing i can think of thats burning em out
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    well i put a meter on the battery when it is running to see if its over charging the reading is 14.01 volts thats normal isnt it , its mainly the side light bulbs and the brake lights that keep blowing i know that they get used alot more than the rest lol
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    it should be 12 volts buddy, unless they drop teh cueent for a larger voltagewould need to check mine
    Mods
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    nah im sure on every car it should be between 13-14 volts otherwise it wouldnt charge the battery because of the things running off the batt like the radio ,lights etc..
    Sportback owner
    Apr 2007
    France
    492
    Fnmrst, it looks like your 12v system is in the normal range. However, all car bulbs are not the same quality. Car bulbs are subjected to lots of vibration, and need to be manufactured properly to make them robust enough for operation in a vehicle. I have seen very poor quality bulbs being sold recently. Don't know where they were made, but just looking at the filament supports inside showed a shockingly poor assembly. Suggest you buy a couple of bulbs from a well-known quality maker and try them out. Probably cost a little more. I did this on my other car, and haven't had a bulb blow in six years.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    Ye in my 2004 A3 i had them blow about once a month, was really annoying
    Currently driving a 55 plate Ford Mondeo ST. But as Arnie once said...
    I'll be back!!!
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    Quote Originally Posted by Geraldy212 View Post
    does this mean i will have to buy some bulbs instead of getting them free lol , yeah i will try that as replacing bulbs all the time is really annoying what do you suggest piaa , phillips or similar cheers for the reply
    Sportback owner
    Apr 2007
    France
    492
    Yup...Philips or Piaa bulbs should be fine. Perhaps those 'free lamps' were not so free after all, lol. Anyway, suggest you try a couple of the better bulbs, and see if they last a long time. If they blow right away, then it would indicate a serious problem with the car electrics. I forgot to mention that on my Sportback, to my best knowledge it has only has had one bulb replaced in nearly five years. It was the driver's footwell bulb. Good luck.
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    thanks i will try that out to see what happens thanks again
    Harrelson's Avatar
    May 2010
    173
    Just to add my brothers rear brake lights blew. Its a 2009 a3
    2009 A3 1.6 TDI Sport Phantom Black, iPod and RNSe
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    warrenty?
    Mods
    Harrelson's Avatar
    May 2010
    173
    Quote Originally Posted by P5SND View Post
    warrenty?
    replaced under warranty. seems a common issue
