Volks AutosAH Fabrications
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    Interior LED Conversion
    Ok this basically was started in the number plate thread but was getting confusing so better in a thread of its own. Things have moved on since the interior LED's were first done last year and now with more bulbs available with built in resistors i want to do a plug & play version of it
    So basically these are the main lights for the conversion:
    Festoons:
    2x Vanity lights
    2x Rear courtesy lights
    2x Front courtesy lights
    Wedge:
    2x Front map lights
    1x Glovebox light
    1x Boot light
    So anybody got any links to the bulbs they used for any of the above?
    Moved to the Darkside click below:
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    Thinking these would be suitable for the vanity/courtesy festoons listed above as i am running them in the number plate with no issues:
    As long as the heat-sink on the back doesn't stop them from fitting into the light units (not alot of space in there) what you guys think?
    2x WHITE 36mm SMD LED Festoon Bulb Light BMW No ERROR K on eBay (end time 16-Nov-10 14:38:42 GMT)
    Gibonz's Avatar
    Vorsprung Durch Technik
    Jun 2008
    111
    I would stay away from bulbs from Ebay mate, all the ones ive got have failed months down the line as they are rated to 12v and sometimes surges can go to 13-14v which will blow it.
    Ultraled's bulbs are rated to 14v and out of all the scores ive purchased over the years, not 1 ever failed.
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    Quote Originally Posted by Gibonz View Post
    are you running an ultra LED interior setup then mate? I've checked out their website but so many to choose from lol Any links to one's your using?
