Volks AutosJMB Retrofits
Results 1 to 10 of 10
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    300 miles on new Sachs Uprated clutch- too soon to fit an Autotech fuel pump?
    Hi as per the thread question.
    Been on holiday and don't use my car to go to work, so until yesterday only had 60 miles on the new clutch!
    Now its got over 300 after a drive down to Sheffield. Was sensible most of the time, it handled full throttle 4-6th gear acceleration fine on the motorway when I felt like testing it out, but on the snake pass the clutch slipped slightly a couple times when going up steep hills in 3rd and 4th gear , when I wasn't being careful enough.
    As you can see I want to get the uprated Autotech HPFP & pump map fitted, as i'm in Sheffield I want to get this fitted now at Stattler ( if he can fit me in ). Im just wondering, although my not-yet-bedded in clutch has been fine mostly, it still judders a tiny bit in traffic and in reverse, so would be ok to get the Autotech fitted now or wait another month? (when I'd have to get it done at Star for more) ?
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    Mar 2008
    Bradford, WY
    788
    I never have had any slipping in mine from the minute it was fitted and im running around 460nm torque! Did you get the flywheel changed? Flywheel is probably the cause for the slight vibrations.
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    DeckedS3's Avatar
    Apr 2008
    South East
    551
    I gave mine beans as soon as I got my clutch fitted and it's been fine.....
    Meteor S3, APR Stage 3, APR HPFP, Milltek TBE, LOBA/Sach's Clutch, Bilstein PSS10's, H&R ARB, Gen4 Haldex PP, EVOM's DV & CAI, Forge TB with Pro-Alloy IC, BBS CK 19" My S3
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,368
    Mine's also been fine.
    Gave it about 100 miles and no drag style starts and since then no problems.
    Will have to see how it copes with Stg3 though.
    chrissy1502002's Avatar
    Portsmouth'ish
    247
    Quote Originally Posted by DeckedS3 View Post
    Me to, found no problems
    Brilliant Black A3 2.0T S-line Quattro Special Edition. S3 front brakes, Turbo back Milltek including race cat, APR Intercooler, Evoms air intake, AMD Stage 2 map, Upgraded OEM DV, Sachs Race Clutch, SMF conversion, Forge short shifters, S3 wing mirrors, S3 Rear end, Interior LED conversion, Bi-Xenon's, LED DRL's, BBS CH's, MY 09 Rear lights, Full leather, Tinted rear windows, Custom black front grills.
    akash_sky1's Avatar
    1,209
    Ok tried it again today after some town driving seemed ok although still hesitant to do a hard launch.
    Yes I did replace the DMF at the same time too. The slight judder is gradually going away, some others on VAGOC who got this clutch also had this issue at first.
    It does smell a bit thought when manouvering in car parks! I was advised to take it easy for 500 miles , you guys dont sound like you did any of that!
    Re Autotech pump steve sold last on on Friday so looks like will be getting it done at Star.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,368
    Quote Originally Posted by akash_sky1 View Post
    I was advised to bed it in gently for about 100 miles,which I did.
    Like most clutches of this type,you do get some nasty smells if you slip it or allow it to get too hot,but if you're sensible,this won't happen.
    Portsmouth'ish
    247
    I ran it in gently for about 300 miles, then was very hesitant to do a hard launch and it also stinks when in slow traffic or round town, glad its not just mine!
    akash_sky1's Avatar
    1,209
    Ok my clutch as plenty of miles on it now. over 500, did some hard driving in the peak district, its ok at mid-high revs full throttle but sometimes STILL slips a low revs/high gear even when im not pushing THAT hard, slightly more so when cold, what gives??!!
    Just spoke to ED @ APS who did the groub buy on VAGOC, he like the others above said this is very unsual esp as the S3s are running much more power and not have reported any slip.
    Anyone else experience a longer bedding in for their Sachs clutch?
    akash_sky1's Avatar
    1,209
    Had the gearbox stripped down, inspected- score marks on the new DMF and clutch disc from the slippage, already.
    No other faults discovered, and new master cylinder was fitted. Transmission re-assembled for the SECOND time. Drive the car...
    clutch slip in 3rd gear 30 mph HALF throttle. FML.
    I think I have been supplied the wrong clutch assembly of incorrect diameter for my DMF. It slips in normal driving and is ruining my new DMF.
    have to wait till next week to see what Sachs Uk dealer is going to do, and whether they will pay for the cat to be stripped down for the THIRD time.
    As it stands car is no good unless driving to the shops, which must be done with great care ! :-(
