Sky InsuranceChris Nott
Results 1 to 17 of 17
    Oct 2010
    2.0 TDi Engine management light help
    Hey, im new to the site and the world of audi's! Ive recently got myself an a3 sportback 2.0tdi and on monday on the way to work the engine management light came on. Ive done a search of the site and i think it might be a common problem that ive got.
    Im a mechanic (for toyota) and have plugged in a snap-on diagnostic machine and got the following codes -
    P3102 Motor for intake manifold flap no signal
    P3101 Motor for intake manifold flap open or short to ground
    P0691 Fan 1 control circuit short to ground
    Ive replaced the fuse in the fusebox in the engine bay and checked the fans move freely and arnt jammed and they seem fine. Started her up and the fuse instantly blew again. Does this point to the IMF rather than there being a problem with the fans??
    Thanks for any help or advice (hope ive posted this in the right section of the site)
    Jon
    tdi-man's Avatar
    Jul 2009
    1,612
    yes m8 i would say imf flap is jamming and blowing fuse
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    51
    you may get away with just cleaning it, but its a common problem. Mine had the same codes, and i just changed it on spec, didnt even try and clean it. IMO if its out, whats the point in putting it back, to find out its still u/s. They arnt overly expensive, from memory about 300 odd.
    Oct 2010
    Ok cheers guys, ive also got to fit a new ABS pump as thats also failed (but i bought the car cheaper knowing this) so i may aswell do both jobs at once. Looks like a weekend of work is in order! So its definately not the fans then, would they only throw the light on if they were jammed or the motors seized? (which they arnt)
    51
    im not quite sure where the fans fit into this fault if im hounest. the fuse is blowing because the IMF is sticking, so the motor/solonoid, not sure what it will be, is drawing to much current. I dont remeber the fan fault code on mine now i think about it...
    maybe some one else can shed some light on that bit for you...
    Hope you get it sorted soon
    Sep 2010
    11
    I wouldn't waste your time taking it off and cleaning it, I have just replaced one on my lad's 2004 2.0 TDi Sport and when I opened it up to see what the problem was, some of the teeth had broken off the cog that operates the flap.
    This seems to be a common problem with cars around that year, the modified part has been redesigned for that reason.
    I picked one up from Euro Car Parts for 211 inc VAT and it took about 1 hour to remove the old one, fit the new part and clear the fault codes.
    There are some good tutorials on here if you search for them
    Sep 2010
    11
    Quote Originally Posted by Matt_ View Post
    I can't recall the exact fault codes that came up on my lad's but there where 3 of them, 2 of them refered to the IMF and the other to the fan.
    The Air Con "Econ" light was on and fuse F8 kept blowing, replaced the IMF cleared the faults and 2 months later just scanned it again and no faults showing.
    EDIT I think these were the fault codes I was getting
    19558 - Motor for Intake Manifold Flap (V157): No Signal
    19557 - Motor for Intake Manifold Flap (V157): Open or Short to Ground
    17075 - Fan 1 Control Circuit: Short to GND
    I hope this helps
    Alan
    I think the A/C fans are on the same fuse as the IMF unit
    Oct 2010
    Ok thanks guys, you've all been a great help. I assume its not worth getting a genuine IMF from audi? i know it will obviously be more expensive. Are the ones from Euro car parts basically the same thing just not in a box with 'audi' written on it!?
    Sep 2010
    11
    Quote Originally Posted by Jonny84 View Post
    They are made by Pierburg, just the same as the genuine Audi part is.
    Roady's Avatar
    Nov 2010
    Hereford
    42
    Anyone have a link to the ones from Euro Car Parts? My searches there don't show any results!
    May 2010
    274
    Car Parts | Car Parts for every make & model | Car Parts Online
    I just got this done 3weeks ago, cost me 300 aswell.
    As for the ABS Pump, my mate got his fixed and it only went and cost him 1200!!
    8P Audi A3 2.0TDI Quattro Sport - what a change from my 1.0L CorsaC!!!
    follow me on Twitter - Jonay1990 for #Photography #Aviation #Mil #Automotive #Subsea
    Roady's Avatar
    Nov 2010
    Hereford
    42
    Yeah but where is the part listed in there, i've done searches for 'intake falp motor','v157', 'Intake Manifold Flap' and none of them return any results.
    Sorry if i'm being dull - i'm no mechanic! (but any computer probs inbox me!)
    Sep 2010
    11
    Quote Originally Posted by Roady View Post
    eurocarparts.com search for "throttle body" or part no. 422440260
    Alan
    Roady's Avatar
    Nov 2010
    Hereford
    42
    Thanks, wasn't aware this part was anything to do with the throttle!
    Oct 2010
    Right well ive now got the new IMF, just havnt fitted it yet as ive been working on my rallycar instead! Ive been searching for a tutorial on how to replace the IMF but cant find one (probably not searching in the right places) is it a hard job? Got the day off today so was going to try and sort it out.
    cheers
    jon
    May 2010
    274
    My garage did it in less than half an hour. Thank god esp. when the rate is 36p/h!
    It's right at the front behind the radiator, I had a look myself and it just looks like unplugging a couple of senors and hoses. Though what would I know?!
    Sep 2010
    11
    cheers
    jon
    I followed the tutorial / thread on this forum some good photos on page 2 off memory
    Click Help - P3103 V157 - Motor Intake Manifold Flap - EGR Valve...How do i solve?
