EM TuningBadger5
    tdi-man's Avatar
    Jul 2009
    1,612
    wheres the main ecu ?
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Jan 2009
    234
    If you mean the engine ECU is beneath your windshield wipers. Remove the wipers, remove rubber and plastic cover. You're there
