EM TuningVolks Autos
Results 1 to 8 of 8
    Sep 2010
    30
    Emissions light. 3.2 v6
    Hi all. Have been enjoying my new toy for the last two weeks until an emissions light came on last Friday under heavy acceleration. This light stayed on for a while, went off then stayed on permanently. It went back to the dealer who said they replaced spark plugs and the light was off.
    Until today that is! I accelerated heavily when the engine was just below 90 degrees on the temp chart and it cane back, flashing
    and juddering heavily as I accelerated. Eventually the light went off, juddering stopped and all was normal.
    Is it normal for the engine to behave this way when cold or is it time to go back the dealers again??
    Sep 2010
    30
    Apologies for the rambling post, sent from my iPhone!
    housey11's Avatar
    Aug 2010
    25
    Just had the light come on with my 3.2 get it plugged in to check fault codes.Look on my previous post and there is a link that shows people local too you that have the vagcom software. Ask nicely and you never know you! as i have found there are some very helpful people out there.
    edition's Avatar
    Nov 2007
    1,417
    Back to the dealers, no warning lights should come on!
    Hellz's Avatar
    Geordie Racer
    Apr 2009
    Newcastle
    372
    I'd take it back to the dealers but as you mention 'juddering' it could be a coil (or maybe more than one) on its way out...
    AUDI S3 2007 Dolphin Grey
    PREVIOUS:
    AUDI A3
    3.2 V6 Quattro S-Line DSG
    AUDI S3 8L
    AUDI A3 1.8T Quattro
    8L
    Sarah's A3's Avatar
    MODERATOR V6 S3 Hybrid
    Cheshire to Perth AU
    5,919
    My emissions light came on when my coil pack failed! Ended up changing them all.
    edition's Avatar
    Nov 2007
    1,417
    That or maybe a lamba sensor......
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    I didnt get juddering with the lambda. My guess is coil pack as its under hard acceleration. Under load the resistance across the plug goes up and the load on the coil increases so more likely to break down under those circumstances
