Chris NottAH Fabrications
Results 1 to 10 of 10
    warren_S3's Avatar
    Oct 2007
    6,201
    Question Can anyone guess what this is?
    Afternoon all; I'm after a bit of wisdom and knowledge as I can't work out what this part is:
    The bit in the red circle. If you look into the engine bay head on, it's directly behind the high pressure fuel pump.
    The plastic cap at the head of the metal unit has broken (possible due to excessive heat / cooling / vibration), and whilst I've managed to cobble it back together with tape, cable ties and a bit of 'jedi' I doubt it will last long. Unfortunately the cheap bit (loom connector) looks to be fine.
    Unit will have to be replaced in full as the plastic connector is an integral part of the unit, there are 2 metal prongs inside it. The unit bolts straight to the top of the engine. No doubt it will be expensive, but saving grace is it looks DIY as there are only 2 (fairly accessible) screws holding it in place.
    Answers on a postcard....
    Warren
    Audi S3 Panther Black [2011] Build Thread
    Mods: Revo Stg2, Blueflame TBE, Eibach Pro springs, R8 oil cap
    On order: Audi S5 3.0V6T Coupe Black Edition, Phantom Black [Due 26 May 2014]
    Planned Mods: Revo Stg1+ with DSG map, Revo CAI, custom exhaust, H&R Trax spacers, EM Tuning LED interior lights, R8 oil cap, Porsche coolant & brake fluid cap
    Top Gear!
    Sep 2010
    N. Ireland
    271
    Im not 100% on this but I think it may be something to do with the ECU, my old golf had something that looked similar to that and when it was removed the power disappeared, don't hold me to it xD but i think thats what it looked like
    warren_S3's Avatar
    Oct 2007
    6,201
    Quote Originally Posted by Stiggles View Post
    Hmmm, if that is the case, I suppose I better not risk it. I'm about to do a 800 mile round trip and this crops up. I suppose I'd better head round to Audi Parts and take my trousers down as I don't want to be stranded 400 miles from home which is where if it goes wrong, its going to happen.
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    Quote Originally Posted by warrencox View Post
    dont forget the vaseline!!
    Gone but not forgotten......
    S
    3 - Phantom Black - Black Optics - Most Extras
    Mods: Revo Stage 2+ - 18" BBS ch/Michelin PS2 - Recaro OEM Buckets - Milltek TBE NonRes/Sports Cat - Evoms Intake - APR hpfp - H&R Springs/ARBS F&R - Sachs Clutch/Luk DMF - AP Racing 6 Pot BBK - 10mm Spacers - Black Rings
    Mods To Do: Full Retrim - MY11 RNSe - Coilovers- Plenty Carbon
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,788
    Not too sure what it is myself, but hope you get it sorted soon with no hassle and its to expensive.
    Quote Originally Posted by S3RYE View Post
    Dark Vader Half sibling - MyThread
    Mar 2009
    120
    Not 100% sure but I think it's the camshaft control valve. Part number 06F 109 257 A
    warren_S3's Avatar
    Oct 2007
    6,201
    Supposedly its a variable valve timing sensor (according to the Audi tech).
    The parts & service guys asked for a look under the bonnet as they couldn't work out exactly what I was asking for. When the saw the mods under the bay lets just say I got the usual gurning face of disapproval because there were unexpected pipes, sponges and bits other trinkets that they weren't expecting. Initially I did think the service tech was having an epileptic fit, but then I realised the disapproving facial gestures are one of the unique ways that Audi UK franchises condescend their customers who choose the path less ordinary (e.g. modification). I hadn't been into a dealership for a while and had forgotten how astute they were at it!! That said he seemed knowledgeable enough, so I can't complain.
    The service guy has just called me with a price of Ł61.52+VAT, so it's bought and will be fitted ahead of the mammoth journey! Shame as it's only a bloody crack in the plastic clip on the top of it, but it puts a fair bit of stress on the two metal prongs inside, and if it was to break I'm not sure I'd want the VVT systems not working!
    For higher mileage cars maybe just worth a check to make sure yours is OK, especially if you've removed your engine cover quite often, or fitted an intake (and potentially exposed this part to any stresses as it was incredibly hot when I just touched it).
    chrissy1502002's Avatar
    Portsmouth'ish
    247
    100% correct, i had to replace mine about a month or so ago.
    Brilliant Black A3 2.0T S-line Quattro Special Edition. S3 front brakes, Turbo back Milltek including race cat, APR Intercooler, Evoms air intake, AMD Stage 2 map, Upgraded OEM DV, Sachs Race Clutch, SMF conversion, Forge short shifters, S3 wing mirrors, S3 Rear end, Interior LED conversion, Bi-Xenon's, LED DRL's, BBS CH's, MY 09 Rear lights, Full leather, Tinted rear windows, Custom black front grills.
    132
    Would it not have been better to go down the independent specialist route?
    A3 3.2 S Line DSG
    A3 TDI S Line DSG Gone
    Update on A3/TT 3.2 V6 software update: See this post
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    its the vvt aka knock sensor for timing
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
