Chris NottBadger5
    Mar 2010
    Cleveland, North East
    214
    Vanity Light Wiring
    My A3 Sport didn't come with sun visor vanity lighting, I fitted an S3 headliner which has them so could really do with connecting them up.
    I'm breaking a Golf Mk4 which has the lighting, so i robbed the loom for them out of this (the visor hinge switches and lights are the same btw, which is handy)
    I'm left with a live feed and earth, and am wondering how to wire them in.
    The earth is easy, am I OK to take the live from the main perm. live feed to the interior light or will this cause issues? I could use one of the two take off point's on the light, the vanity lights would only work when the headlights are on though.
    Aug 2008
    408
    Take feed off a switched live at fusebox m8
    Cal
    Mar 2010
    214
    Did consider doing that, but they usually work when the ignition is off, hence the perm live.
    Taking a wire down the A-pillar to the fusebox is a possibility, but would rather not is there is an alternative, which I suspect there is.
    Aug 2008
    408
    There is perm live fuses at fusebox you
    Can use, coincidentally im doing this mod
    Just now with illuminated a4 sunvisors.
    Cal
