Sky InsuranceAH Fabrications
Results 1 to 8 of 8
    Nov 2004
    34
    pause in power between 3rd and 4th
    When i boot the car useing the full rev range going between 3rd and 4th i got a drop in power for about 2 seconds and then the car picks up again is this normal as it just seems a bit weired to me ???
    it only does it if you use the full rev range (short that it is )
    [img]/ubbthreads/images/graemlins/cool.gif[/img]
    Re: pause in power between 3rd and 4th
    Are we talking about a manual or DSG gearbox. I have a DSG and get no loss of power if I'm using D, S or tiptronic.
    Nov 2004
    34
    sorry its manual
    loftusrich's Avatar
    Nov 2004
    Teesside
    13
    Characteristics of driving a diesel?
    Rich
    Nov 2004
    34
    i thought that but it dosnt do it all the time and dosnt do it if you hold back a bit [img]/ubbthreads/images/graemlins/shocked.gif[/img]
    booked in at the stealers to get the new gearknob fitted so will get them check it out [img]/ubbthreads/images/graemlins/angel.gif[/img]
    Mar 2003
    UK
    426
    Did you bounce off the rev limiter before changing to 4th? Can that mess with things as the power is cut to prevent over revving?
    Nov 2004
    34
    no bouncing off the limiter
    Mar 2003
    UK
    426
    If it happens consistently everytime, there is defo something wrong. Take it to the dealer.
    I rarely go beyond 3000-3500rpm. But when I do, I have no such hesitation.
    Admittedly, on Sunday I noticed a very slight hesitation when changing up (couple of tenths of a second), but I but that down to the cold engine and very wet atmosphere. I'll see whether it plays up again in normal conditions.
