Sky InsuranceBadger5
    Jul 2010
    10
    Audi A3 on Start Up its miss fires
    Hi Guys,
    What is the cause of my Audi A3 2.0tdi 53 plate 8P chassis etc etc, when I start the engine first thing the car seems to cuagh and splatter when idling, like is sounds as if its miss firing, but when the engine heats up the engine "when idling" runs as per normal.
    I am thinking it maybe the glow plugs!!!
    Does anyone know the cause of this?
    And can anyone recommend high spec glow plugs for this type of car??
    Your input would be much appriaciated.
    cheers
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    yeah either glow plugs or the connections to them, or a fuel leak at the rail feeding the injectors can cause rough starts. Be careful taking the old ones out as they stick and snap in the head, so get the engine warm, and spray release agent liberally on them before trying to unscrew them. If they are very stiff, spray them again as soon as the "lock" is cracked off, before turning them any further to prevent breaking them. work them gently back and forth a quarter turn till they rotate smoothly.
    Try these:
    Denso Audi - Euro Car Parts UK
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    tdi-man's Avatar
    Jul 2009
    1,611
    search idle in the search bar m8 lots of reasons can cause this
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Jul 2010
    10
    cheersa guys will do
