Sky InsuranceChris Nott
Results 1 to 7 of 7
    Jan 2009
    A3 2.0 TDI 140 BKD Juddering 5th/6th Gears under load
    Hi
    I'm wondering if anyone can suggest what might be wrong...
    I had my A3 remapped yesterday. Today I have noticed that every time I accelerate hard (foot flat) in either 5th or 6th gear the car shudders (feels like the wheels are spinning) between about 1600-1800rpm and then continues to accelerate as usual.
    heeman10's Avatar
    Audi driver since Dec 08
    Dec 2008
    Somerset
    388
    Dual Mass Flywheel judder. You shouldn't be flooring it down at those engine speeds anyway really, remap or not, but the remap will exacerbate the problem. Leave 100% throttle acceleration till 2,000-2,200rpm or so and things should be okay
    .: 2005 Dolphin Grey A3 2.0 TDI Sport :.
    Jan 2009
    Thanks heeman10,
    Is this something that should be expected with a remap?
    Or is it due to the DMF or clutch being worn?
    heeman10's Avatar
    Dec 2008
    Somerset
    388
    The flywheels on some cars judder in standard form if they are driven at low revs and loaded up. Which remap do you have, out of interest? The dual mass flywheel is a bugger for this!
    Jan 2009
    Its from AMD Essex.
    I never had anything like this before the remap - except for when I'd choose a gear too high and the car would judder, but this is different as it begins to accelerate, then judders, then continues to accelerate...
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    clutch could be on the way out..
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    heeman10's Avatar
    Dec 2008
    Somerset
    388
    If you search the net you'll find a lot of similar stories matey. It should be fine if you don't use much more than 50% torque until you're happily clear of 2,000rpm. It's not kind on an engine to load it up at low revs anyway, without having the added problem of the DMF thrown in.
