Results 1 to 11 of 11
    132
    A3 Autolights - is this right?
    I have autolights, fitted from manufacturer and when I put it on O (off), the lights are very dim, but when I put it on auto or the 2nd option it turns the lights on (side lights I think its called? and then at night the xenons work fine.
    My question is; can the lights never be turned off? Seems to be 3 stages; dim lights, side lights and fully on.
    Not too good at technical terms for them but you get the dea
    A3 3.2 S Line DSG
    A3 TDI S Line DSG Gone
    Update on A3/TT 3.2 V6 software update: See this post
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    If you have auto lights, there should be a stage between 0 and sidelights that says "auto"
    Should look like this:
    I think you're on about the DRL's (daytime running lights) which are always on. However you can change this by going into the car options if you have the RNSE or using VAGCOM
    Currently driving a 55 plate Ford Mondeo ST. But as Arnie once said...
    I'll be back!!!
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Smudge
    He says "but when I put it on auto or the 2nd option it turns the lights on "
    Auto is the 2nd option so he has auto so should they glow dim in the off position ? well no, sounds like a bad earth to me but Nige is our electrics bod.
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    Quote Originally Posted by paddy View Post
    Smudge
    He says that the sidelights come on, so either he doesn't have auto lights and therefore has a switch with 3 stages, or he is thinking that the DRL's are sidelights, which they're not
    In "auto" the DRL's are on all the time
    I'll be back!!!
    Mar 2010
    Grantham UK
    39
    For info:-
    2010 Sportback with Adaptive Xenons
    In the off "0" position everything is off including DRLs, Auto does its own thing (a bit too sensitive for my liking, headlights are on far too soon), Side lights setting brings on DRLs only and Headlight setting turns on Head lights manually. No DRL dimmer or switch on the panel on my version though!
    scottie123's Avatar
    Oct 2008
    1,888
    A3 rider
    Please clarify what year your car is, this will help us to help you.
    It seems unclear at the moment what you have
    05 SB SE BKD
    Build Thread
    May 2010
    2,502
    Quote Originally Posted by A3_Rider View Post
    take a photo of your headlight control panel
    2006 Phantom Black A3 2.0T S-Line.
    DSG | 18" BBS Pescaras | Rear Parking Sensors | MFSW | Symphony II | BOSE | Auto lights/wipers | Half leather
    MODS : '09 tail lights | TT vents | Weitec Hicon GTs | RNS-E 2010 | Controls Pack (Red Stitching)
    PLANS: Dumbos | 8P3 S-Line Rear Bumper | OEM Parking Sensors
    GONE BUT NOT FORGOTTEN:
    2005 Ebony Black A3 1.6 Sport tiptronic. You will be missed!
    1997 BMW 316i Coupe M-Sport. You won't be missed quite so much!
    132
    Never had autolights or xenons before. I thought DRL was the height the lights would be at!
    Changed it to 0 and they go off now - what is the purpose of the DRL? Also what is that button below the DRL?
    I will read the manual in an hours time too lol
    A3 3.2 S Line DSG
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,122
    drl is daytime running lights so you should have in position 0 no lights on in position 1 (on the drl switch ) drl if i think they are in the middle of the headlights looks like sidelights but brighter and if you turn sidelights on then the drl will go off so leaving just sidelights on and then zenon's on for the main headlights , the button below is for the coming home / leaving lights
    off the road boohoo anyone got a gearbox for me lol!!
    132
    I was wondering about them as my friend has them on his R32 DIS and I couldn't see it on mine - thanks!
    A3 3.2 S Line DSG
    20
    Quote Originally Posted by 8ig_steve View Post
    For info:-
    AGREE. Anyway we can adjust its settings? To let it stay at its brightest at all times?
