Chris NottVolks Autos
    Aug 2007
    Funny Idle and 15mph-30mph jerky
    Hi Guys and Girls
    I have a strange problem with my 54 reg A3 2.0 sline DSG, BKD. I have searched all the threads and forums and everything I have tried seems to fail and now I have spent over 3k trying to fix this problem. What the problem is when I start the car from hot or cold the rev counter sits at 830 then drops to under 800 then revs back up to 1k but this doesnt happen all the time (especially when I have an audi tech sat next to me!) also when driving between 15mph 30mph it judders like I am a bad driver in 3rd gear these two problems started about 3 months ago. I took it into audi and 6 other garages! And each have stuck it on the vag com and all came back with no faults! I did tell them it had been done 6 times before but it must be a standard charge and proves there are no faults @ 60 a time!
    I had problems with my MAF so I changed this (twice), I had 4 new glow plugs (Bosch) as number 4 in the early days was reporting a fault, I have replaced the throttle body as this was sticking and blowing the aircon fuse, I have a new EGR as it was blowing smoke now and again and jerky gear changes, I have had a new turbo hose, a new turbo, its been serviced 3 times (new air filters, oil and fuel filters) its been cata cleaned, injector cleaner ran through it, fuel pump, fuel can cleaned but still the problem persists. I nearly lost it and traded it in on a new focus st3 last weekend but as mine has every extra on it nothing comes close to how I feel about my a3! Can anyone help me or do I just cut my losses and trade it in against something else? As everybody i know is telling me to get shut! But I just cant bare to let her go without a fight!
    Fossie
    Rhubarb Triangle
    3,969
    Injector wiring loom has been known to cause this problem. It does not show on Vagcom (VCDS)
    Not that expensive to replace I believe.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Throttle body on TDI ?
    VCDS USER
    Aug 2007
    Quote Originally Posted by SAiLO View Post
    Yes if thats what the part is called thats connected to the EGR
    tdi-man's Avatar
    Jul 2009
    1,611
    idle flap
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
