Sky InsuranceJMB Retrofits
Results 1 to 10 of 10
    Aug 2010
    chester
    247
    front and rear lights
    hi does any one know if i can fit these as a direct replacment for the original ones, not having to mess with wires or anything.
    eBay - The UK's Online Marketplace
    also the facelift 2009 rear lights are these easy to fit or does it require changing lots of things? i have tried to find a guide to fitting them.
    A3 2009 2.0TDI sport aruba blue - 17" alloy wheels, half leather and alcantara seats, bluetooth telephone prep, aux, electric lumbar support, puddle lights, vanity lights.
    mods so far - tinted windows, my11 rear lights.
    scottie123's Avatar
    Oct 2008
    1,888
    Those front lights are standard A3 HALOGENS. . There is no differance afaik between s line and se sport etc.
    The rear lights are very very easy on the 3 door. You change them the same way you would change a bulb in the cluster. Look in your hand book and it will be clear
    HTH
    Aug 2010
    chester
    247
    so all i would need to do for the rear lights is remove the actual light and replace it with the new 1?
    so the front is jus unscrew original and put the new 1 in its place and it will fit perfectly?
    Oct 2008
    Telford
    2,488
    Quote Originally Posted by kirsty76 View Post
    yes and yes! 5 mins a side maximum! Lots of people have upgraded the rears to 09 and now 11 spec.
    As for the fronts in your link, they are the same as the ones you have so dont buy them!
    B6 1.8T Avant s line gmbh
    Fossie
    Rhubarb Triangle
    3,969
    Your mods so far say you have xenons. Why would you want to change back to halogens ?
    Aug 2010
    chester
    247
    no i dont have an s line they hav black insides mine are grey and i think they may have a hole.
    scottie123's Avatar
    Oct 2008
    1,888
    you can get them cheaper than that on ebay. If they are black, I would imagine someone has sprayed them that colour!!
    Aug 2010
    chester
    247
    does the s line not come with black insides of the headlights then?
    heeman10's Avatar
    Audi driver since Dec 08
    Dec 2008
    Somerset
    388
    If you want to downgrade to halogen lights I'll gladly swap for your xenons!
    .: 2005 Dolphin Grey A3 2.0 TDI Sport :.
    Oct 2008
    Telford
    2,488
    No they are identical on all models! The seller is after makin a quick buck
