Monster MotorsportEM Tuning
    IS IT POSSIBLE TO DISCONECT THE REAR DIFFERENTIAL FROM MY 2008 S3?
    Hi guys, I have a 2008 Audi S3 2.0TFSI with some mods and I would like to know if it's possible to "disengage" the rear differential to test it in a 2wd dyno.
    Has anyone done this in this car?
    I would really appreciate all the help that you can offer me.
    thanks.
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,723
    Just pull out the fuse for the Haldex.
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
    heeman10's Avatar
    Audi driver since Dec 08
    Dec 2008
    Somerset
    388
    Fuse-pulling is a scary practice. I would never let a car on my rolling road with "the fuse pulled". A number of owners tried to press me into allowing it, but it's simply not bright. If any electrical malfunction were to occur that closed the circuit and transmitted torque to the rear wheels, the owner would most likely swallow his words when his car hurled itself off the rollers.
    Yes, it is a case of "Yeah right, you'd have to be well unlucky for that to happen", but it's not a risk I would be willing to take. Risk/chance/luck - none of these things mean definite yes or definite no. If you disconnect the rear prop, you will never run the risk of your car deciding to make a quick exit through the front wall of the dyno cell!
    .: 2005 Dolphin Grey A3 2.0 TDI Sport :.
    netr's Avatar
    Jun 2010
    Ljubljana, Slovenia
    51
    nicely put
    RAPS3's Avatar
    Moo Moo Land
    1,086
    It's not just a case of pulling the fuse, you need to turn off certain sensors in Vagcom, speed sensors to the rear wheels and others i beleive.
    I know someone who had their S3 RR'd on a 2WD RR recently without issue.
    Paul R
    S3 Sportback - Sprint, Buckets, Bose, Rain & light, Alu rails, Piano trim, FT Warning, Bluetooth prep
    S3's now sold - roll on the Golf MK1 Project
