Volks AutosAH Fabrications
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    MAF Replacement on BKD Engine
    It's probably been asked a million times before but I can't seem to find any guides.
    Do I only need to unscrew two torx screws on the pipe that are facing the cabin or is there anything else I need to unscrew before taking out the old mass airflow unit and replacing it with a new one?
    If someone had a pic it would be great!
    Also do I need any special tools?
    VCDS USER
    27,099
    No, its a piece of piss tbh, I'd remove the spring clip so you can get to unscrew it easier, some adjustable pliers like are perfect for this.
    Halfords | Halfords Waterpump Pliers 250mm
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Cheers Nige!
    So is it only 2 screws? What about the two screws that hold the socket on the pipe?
    VCDS USER
    27,099
    The maf is that whole unit, dont touch the sensor screws, they replace it all.
