Volks AutosBadger5
Results 1 to 7 of 7
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    Clutch replacement labour costs?
    Hi I am getting my Sachs clutch and new DMF fitted sooon just wondering what I should expect to be quoted in the region of for the labour costs?
    cheers
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    It takes about 5 hours to do a complete clutch install on a quattro for the labour. It can be done a lot quicker if they know what they are doing and everything goes to plan.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    akash_sky1's Avatar
    1,209
    Well I'll what my usual Audi specialists say to that....hopefully it'll go to plan unlike my DP which took them ages
    Feb 2007
    Harrow
    221
    You might wanna change the slave cylinder at the same time.
    Audi A3 54 plate 2.0 FSI Sport
    www.simplydents.co.uk
    Mods - 11 Rear lights, custom front matt black grille, I pod connection, S3 rear spoiler.
    akash_sky1's Avatar
    1,209
    Getting a good friend/mechanic to do this now..getting release bearing obv but not changed slave cylinder before when I had a new clutch?
    Feb 2007
    1,257
    Why would you change the slave cylinder ?
    akash_sky1's Avatar
    1,209
    Quote Originally Posted by devonmikeyboy View Post
    Yeah I wasnt aware you needed to do this routinely as a precaution like with the release bearing?
    Getting a friend/mechanic to fit clutch AND H&Rs for 220-250 ish. On a side note...the DMF is one HEAVY piece of kit. Must loose a good 5hp atleast just spinning that badboy.
