Led bi xenon vagcom coding help
neilwaterhouse88
NULL
Hi guys I have a 59 a3 and have had the genuine led headlights fitted and was wondering if anybody knew how to make the led lights stay on full brightness when the side lights are on? Also at the moment when the light switch is off the drl still stay on the company that fitted them are sending a new light switch as they say that will solve the problem any ideas?
so you got xenons retrofitted the light switch will solve the lights on all the time problem butim not sure what you mean b the leds dimming, they dim when you indicate and you can turn that off with vagcom
Well the led's are really bright when in drl without any other lights on but wen I turn the side lights on the led's are on with the rear lights but much dimmer, thanks for your reply
sounds like its wired incorrectly hopefully the pinouts are different on the switches and will rectify it it should if not dont hesitate to post back and ill advise to teh best of my ability
