Chris NottMonster Motorsport
Results 1 to 27 of 27
    c_w
    1,047
    How to remove climate control unit switches/facia?
    Hi, can someone help on how to remove the climate control unit? I've removed the radio but can't see any obvious clips or screws for it. I want to get to the back of the unit, thanks.
    Sep 2007
    Ellesmere Port
    160
    it just pulls out, but if it's at the bottom, then if am remembering correctly you have to take the side handles off, an there 2 screws under gearbox cover as well to get the handles off... then just pulls out.
    Audi A3 2.0 TDI Sport, Hybrid Turbo, Sat Nav RNS-E, Bluetooth, Bose, Parking Sensors, Custom Bluefin Map, Black Diamond Drilled and Groved Front Discs, Black Diamond Preditor Pads (All Round), Roof Spoiler, Cruise Control.
    c_w
    1,047
    Thanks, my car has the standard single DIN radio so the climate is in the "middle", so it lerally just pulls out!? Where's best to pull as I did try it a little but didn't want to break anything (this was with the radio out).
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    pul solidly from the bottom and the top it will come out same procedure for both double and single din
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    26,722
    Problem with just yanking them out is the clips can ping of & get lost in the center console, I strongly advise not doing this as its a strong possibility whole console out if this happens as could have a constant rattle from the clip whilst driving.
    The spring clips need to be depressed slightly to remove climate easily, once 1-2 are loose the other 2 dont need touching as they are made loose by the lack of pressure on the other 2/unit fixing, get torch in there & have a poke about.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    never had that happen but then i usually yank the bottom and ease the top out with plastic spreaders
    Mods
    26,722
    I have & believe me its a big ball breaker when it does, I mean massive, found 1 hidden under the airbag controller, but of course cant get to this without the whole center console coming out.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    center console still isnt that bad a strip though but i must admit id be pissed if it happened to me
    Mods
    26,722
    Depends whose doing it huh Phil lmfao
    Khufu's Avatar
    West coast of Scotland
    5,693
    I guess I too have been lucky!
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    i had one go ping when i fitted my hands free kit in my car now its rattling its tits off behind the radio somewhere i'll pull it apart sometime its doing me head in so i can strongly recommend doing as nhn says
    off the road boohoo anyone got a gearbox for me lol!!
    26,722
    I rest my case lmfao, thats a ***** to find aswell, double sided sticky tape helps on end of a coat hanger.
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,120
    oh yeah it seams that way lol, i'll give it a crack tommorow sometime
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    haha guess ive been lucky guys as ive taken units in and out 20+ times now with no problem
    Mods
    26,722
    Thats cause all your spring clips are now in the footwell lmfao
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    haha its been on other cars, and they were always still in place its my magic hands though the missus probably has some witty retort to that
    Mods
    c_w
    1,047
    Well it came out with a bit of a harder but controll pull! Thanks. It felt to me that the top unclipped and then it kind of came out and unhooked from the bottom.
    26,722
    Quote Originally Posted by P5SND View Post
    Quote Originally Posted by c_w View Post
    Does this read as though we're on a car site or what lmfao
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    haha nige weve gotta liven up a sunday somehow
    Mods
    c_w
    1,047
    Did it again today and it was much easier coming out this time hehe
    26,722
    I hear swarfega would make it easier with a slight bit of roughness lmfao
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    aww thats just wrong mate, on the other hand i hear barrier cream can help deal with friction burns
    Mods
    26,722
    lmfao, bit like philadelphia, wrong but so right lol
    Be Gentle
    Sep 2010
    Kent, United Kingdom
    116
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    this thread went downhill very quickly, without the usual crew too
    Mods
    26,722
    whats that say about us then Phil lmfao
  28. #27
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    oh shi lol too truemate too true. need a holiday!
    Mods
