I've now had the car on VAGCOM and it's come up with a few faults. There's a couple of faults relating to heating but I've already found that if I unplug the dash clocks the climate comes back on as normal. The fault for the instruments is "00532 Voltage B+ - Upper Limit Exceeded". Can anyone help at all?
As said the car drives fine, there's no problems with anything else apart from the instruments (some of the lights work, like andbrake, battery, cruise still works fine etc), but the dials, computer DIS etc don't come on at all. One thing I want to try is a second set of clocks as they're so easy to change. Does anyone know of a car being broken or someone have a spare set of clocks from this age car I could try to narrow it down?
2.0 TDI BKD 2006
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 LG HW: 03G 906 021 LG
Component: R4 2,0L EDC G000SG 9179
Revision: --H02--- Serial number: AUX7Z0F6FNB0H5
Coding: 0000072
Shop #: WSC 00654 210 91815
VCID: 6FE62A4907EF
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
Shop #: WSC 06314 000 00000
VCID: 73EE26396BC7
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 M HW: 8P0 820 043 M
Component: KlimavollautomatH18 0300
Revision: 355891 Serial number: 8P0820043M
VCID: 3668DF2D3835
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 3
Reset counter: 60
Mileage: 50903 km
Time Indication: 0
Date: 2010.09.16
Time: 00:44:17
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000005966229
Coding: 01884F07A214100000000000000000000008FE175C0200
Shop #: WSC 06314 000 08192
VCID: 4084B9F56AF1
Part No: 8P2 955 119 B
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
Component: Airbag 9.41 H12 3720
Revision: 91H12372 Serial number: 0037W002JBA+
Coding: 0071612
VCID: 4796A2E94FDF
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H37 0070
Coding: 0000042
VCID: 4182BCF161FB
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 F HW: 8P0 920 981 F
Component: KOMBIINSTR. VDO H18 0560
Revision: D0H18002 Serial number: 2246F002003023
Coding: 0004413
VCID: 3B7ECE190317
1 Fault Found:
00532 - Supply Voltage B+
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 21
Mileage: 50921 km
Time Indication: 0
Date: 2010.09.16
Time: 01:05:11
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 G HW: 1K0 907 951
Component: J533__Gateway H10 0140
Revision: H10 Serial number: 30001067028793
Coding: 3D0F0B4207000101
VCID: 2B5EFE59F377
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D0H18002 Serial number: AUX7Z0F6FNB0H5
Shop #: WSC 00000 000 00000
VCID: 3B7ECE190317
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0000560
Shop #: WSC 06435 000 00000
VCID: 4084B9F56AF1
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.078 H07 1806
Shop #: WSC 00654 210 91806
VCID: 356AD8212533
1 Fault Found:
00750 - Warning Lamp
013 - Check DTC Memory - MIL ON
Freeze Frame:
Mileage: 50910 km
Temperature: 26.0°C
Voltage: 12.30 V
Voltage: 12.10 V
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 C
Component: KSG H04 0050
Coding: 198000186D288505489AC63300
VCID: 3C7CCD050619
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH27 0160
Revision: 00005 Serial number: 30659635428607
VCID: F0E4A9359AD1
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000560
VCID: 4182BCF161FB
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H52 0100
Revision: 02S Serial number: AUZ2Z3F4209471
Coding: 0001001
VCID: 3260E33DD45D
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5AF041CD63
1 Fault Found:
01320 - Control Module for Climatronic (J255)
