Chris NottAH Fabrications
Results 1 to 7 of 7
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    Will a Sachs DMF fit a car that originally had a LUK ?
    Hi people going to be fitting the reinforced Sachs clutch disc and pressure plate to my car and need to replace the DMF as well which is totally knakerd..
    Does anyone know if a Sachs DMF will fit my car as hear this can allow for higher clamping forces due to its dimensions?
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    Oct 2009
    99
    Hi mate Sachs dont do a DMF they only make the single mass flywheel.
    If you want a DMF it has to be the oem LUK one which does the job fine.
    Did mine a few months back ;-)
    SILVER S3.......GIAC ECU & FLASHLOADER.....ITG INTAKE.....SACHS ORGANIC CLUTCH........ROLLING @ 328bhp...321lbs/ft
    akash_sky1's Avatar
    1,209
    Ok I was browsing thru the Sachs site and wasn't paying attention...can't wait to get this and the Autotech on and for some beasty driving again. Interesting to see how it handles hard launches once its bedded in.
    Jul 2007
    London
    3,086
    LUK is part of the Sachs group so yes, they do DMF's ! On some models the DMF are interchangable but dealers allways change like for like ! I would get in touch with people from sachs and see what they say.
    FOR SALE:
    tdi-man's Avatar
    Jul 2009
    1,589
    i changed my luk clutch and dmf for a sachs one
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    934
    Sachs do make dual mass flywheels. Got one fitted in my A3.
    VCDS USER
    chrissy1502002's Avatar
    Portsmouth'ish
    247
    Forget DMF and go the whole hog and get a Sachs group N race clutch and SMF, you wont regret it! lol
    Brilliant Black A3 2.0T S-line Quattro Special Edition. S3 front brakes, Turbo back Milltek including race cat, APR Intercooler, Evoms air intake, AMD Stage 2 map, Upgraded OEM DV, Sachs Race Clutch, SMF conversion, Forge short shifters, S3 wing mirrors, S3 Rear end, Interior LED conversion, Bi-Xenon's, LED DRL's, BBS CH's, MY 09 Rear lights, Full leather, Tinted rear windows, Custom black front grills.
