Results 1 to 9 of 9
    heeman10's Avatar
    Audi driver since Dec 08
    Dec 2008
    Somerset
    388
    2.0 TDI cut out after 30 seconds of running
    A couple of mornings ago I started my engine, let it idle for ten seconds, crawled away in first gear, upshifted to second at about 1,800rpm, light throttle again in second to about 1,500rpm, lifted off for 2-3 seconds round a gentle corner (in a housing estate) and the engine juddered. I put the clutch in straight away and the engine cut out without a second. It wasn't a stall, and nothing seemed untowards under the bonnet. I got back in, gritted my teeth and turned the key, and it fired up fine and didn't give me a problem.
    76,000 miler, never had a problem like this before or since. Any clues?
    .: 2005 Dolphin Grey A3 2.0 TDI Sport :.
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    youd have to scan it for codes mate, could have been a glitch in a sensor, or some intermittent gremlin that may resurface later.
    Mine has stalled after starting once, and for a couple of days it was shuddery on start up, but no codes, so may be glowplugs in my second case but still not figured out the stall. Plus yours has even more electronics and cant run without it, the old AFN in mine will run with no ecu almost, as long as the fuel cut solenoid has power lol (wont get boost but hey you'll get home) - cant think of an obvious reason tho except sensors or fuel pressure or something.
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,043
    Any warning symbols on the dis?
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    heeman10's Avatar
    Dec 2008
    Somerset
    388
    No lights on the clocks, no DIS warnings, sounded as though someone had put a clamp on my fuel pipe the way it stopped. Do the fuel pumps tend to give trouble on these? VCDS would be very useful at times like these!
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,043
    Not a diesel but I had cutting out problems are few weeks back.
    But I was seeing various lights on the DIS.
    Turned out to be a power supply relay to all of the main Control Modules.
    Took a week to replicate and diagnose the fault, and 11 for the part.
    Good luck.
    Paul
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    heeman10's Avatar
    Dec 2008
    Somerset
    388
    Okay Paul, I'll bear that in mind Not quite as bad as the Mk5 Golf TDI I came across stranded in the middle lane of a three-lane M5 roundabout under a bridge last night, hazards on..young mum with two young boys in the back. She'd brimmed it from empty with unleaded! Whoops!
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    get a cheap ebay vag lead that works with version 409 of the older vag com, its still bloody good and waaaaaaay cheaper than the original one or the new vcds.
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,043
    Quote Originally Posted by heeman10 View Post
    Oops.
    Mine started cutting out when I was driving too (no brakes or steering) but luckily I was in dual contraflow so was only doing 10mph or so and one lane of traffic could still squeeze past.
    Im sure I was dead popular as it was at the Tyne Tunnel peak rush hour. Horrible spot to negotiate during busy periods anyway.
    Paul
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,851
    low oil???????? fuel pump fuse blown? (if its starting after a few cranks)
    Full leather/19"wheels/cruise/
