Chris NottBadger5
Results 1 to 31 of 31
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Parking Sensor Retrofit
    Alright guys
    Can this be done?
    How much for 4 off rear sensors and wiring?
    Part numbers?
    Pity this needs painted but at least it is sprint blue, already has the holes and I would have spare spoiler to sell on.
    GENUINE AUDI S3 A3 REAR BUMPER AND SPOILER NO RESERVE!! on eBay (end time 18-Sep-10 20:01:07 BST)
    Or, does anyone have the dimensions and positions for the rear sensors?
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    depending on how much you get the bumper for, you would defiantly get 50 for the lower valance, always sought after as they fit the s-line bumper!
    ps you would also have your S3 air vents to sell lol i want them they match my rns-e button
    Moved to the Darkside click below:
    May 2010
    2,502
    apparently the bumper is marked on the inside with an + at the parking sensor positions. Nigel didn't use a parking sensor bumper he drilled a regular one (using the aforementioned +s) and used mounting points for an A6 with some epoxy. it's in his thread, which i currently don't have time to find.
    don't waste your time buying another bumper.
    2006 Phantom Black A3 2.0T S-Line.
    DSG | 18" BBS Pescaras | Rear Parking Sensors | MFSW | Symphony II | BOSE | Auto lights/wipers | Half leather
    MODS : '09 tail lights | TT vents | Weitec Hicon GTs | RNS-E 2010 | Controls Pack (Red Stitching)
    PLANS: Dumbos | 8P3 S-Line Rear Bumper | OEM Parking Sensors
    GONE BUT NOT FORGOTTEN:
    2005 Ebony Black A3 1.6 Sport tiptronic. You will be missed!
    1997 BMW 316i Coupe M-Sport. You won't be missed quite so much!
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    Cheers mate - I wouldn't fancy drilling my only S3 rear bumper to fit sensors.
    I will have a look for nigels thread!
    Apr 2006
    england
    754
    mate if you do go ahead i retrofitted the parking sensors, with advise on that tread from NHN, if needed let me know i will give you all the parts numbers and wiring,
    Apr 2006
    england
    754
    oh now me looking to fit the reversing camera, the one the replaces the number plate light, best thing is its going to cost 70 mark,
    May 2010
    2,502
    p/n would be useful to me ta very much!!
    27,097
    That bumper will need repainting for sure with that damage, as spot repair imho would be noticeable, I reckon its cracked surround areas aswell, so the current colour is totally irrelevant.
    Dont be a tart Boycie, drill your existing, paint sensors, glue in place then sikaflex after testing sensor system is functioing properly, job done.
    Which system you want to fit, oem or aftermarket?
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    Considering OEM more than aftermarket - want to tick off as many retrofits as possible!
    Kufatec are selling their unit though but its a tad expensive!
    terrymcg's Avatar
    Nov 2006
    West Lothian
    236
    Did you ever get around to doing this mate?
    57 Plate Imola Yellow S3
    brough74's Avatar
    Oct 2010
    423
    Ive had it done on 2 previous audis by the main dealer, if you can negoiate it costs between 250 to 450 which includes everything and painting.
    Dean's A3's Avatar
    TDI S3 Hybrid
    May 2010
    261
    That will not be for the optical system me thinks. You can get those analogue ones for about 50...
    27,097
    There are 3 systems from audi, 2 are factory & 1 is after market, there is audio based thats integrated into the canbus with possible dis settings for tones/volumes which also integrates with towbar fixings this is the norm factory fit version, then there's the more advanced optical version factory fit that shows in your nav display that is nowhere near 250-450 & then there's the cheap ebay 20 reverse wire system that audi installs aftermarket for a horrendous price.
    Of course both factory systems can be retrofitted as I've done them myself.
    May 2010
    2,502
    nigel what was the consensus on fitting front sensors to older cars?
    27,097
    In what context, cost, complications etc?
    May 2010
    2,502
    Both really. Would you need a new central electrics unit from the 8P3s?
    c_w
    1,061
    Don't see the point in retrofitting geniune AUDI kits if they're 250-450 when kits off ebay can be had for 15 or so!! And they seem to work fine, installation is also very easy and the sensors look OEM. Sure you don't get to geek about in VAGCOM other than a different bonging sound and nobody really needs a reverse CAMERA in an A3! :D
    May 2010
    2,502
    Quote Originally Posted by c_w View Post
    i don't think that necessarily a fair assessment. the Audi OEM kits are cleaner looking, and you can only have optical parking on your RNS-E if you have a factory kit fitted. i can understand the appeal, and for 250ish i'd be able to understand the price. at 450ish tho i'd be inclined to agree with you
    27,097
    TBH aftermarket kits have mostly looked pants compared to oem, albeit hell of allot cheaper, but integration is better for oem, not everyone likes the same tones, volume etc, so dis features are good for these people.
    Costwise would be personal preference what you call expensive for what system you get, for me the optical parking system is good, as long as you spec'd the rns already for other use, not just pdc, but as I said people's perception of expensive for a function is different.
    Cant say if anyone would need new modules, as its down to the individual case, certainly has to be supported by various modules, so its a possibility some have to be added/upgraded/coded.
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Who on earth need sensors on a A3 !! I mean its only 3ft long and the back window is the back of the car .
    May 2010
    2,502
    Quote Originally Posted by paddy View Post
    anyone can make a mistake. i'd rather pay a few hundred quid for sensors on a car than a few hundred quid for a new bumper. and if your missus drives the car then you really should have them
    Dean's A3's Avatar
    TDI S3 Hybrid
    May 2010
    261
    I have reverse camera AND reverse sensors just for the Mrs so she has NO excuse!
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    In that case.....stop at a bus stop and grab a poor person, keep them in the boot for just such an occasion. I get mine to stand between the car and the obstacle and when he yelps....i stop. simples
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    you can have my parking sensors if you want, they are a pain in the ass!
    May 2010
    2,502
    shotgun
    Nov 2010
    15
    Hi
    I've got parking sensors fitted from new to my S3, no sat nav (can't take it with me to find the way in cities from car parks that I can with a Tomtom), not noticed any way to change the sound, so they do not do anything more than cheap ones unless you have sat nav fitted?
    Regards Gray
    2008 S3 Red
  28. #27
    Khufu's Avatar
    West coast of Scotland
    5,693
    TBH, it makes you lazy. You just keep reversing without really looking until the tone goes solid LOL.
    I'm sure you dont will need the 8P3 CE module for front & back sensors, maybe if you want the full park assist that parks for you though? (coupled with White facelift cluster)
    Quote Originally Posted by crunchie View Post
  29. #28
    JohnS3's Avatar
    Oct 2004
    3,021
    look under settings in the DIS
  30. #29
    Khufu's Avatar
    5,693
    That might depend on the module revision etc fitted John, I have an original PDC module (pre any suffix) and despite a 2010 gateway module & latest white LED cluster & newer convenience module, I dont have any access to my parking sensors via the DIS.
  31. #30
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    When i bought my A3 the dealership said they don't fit sensors but farm it out to a local shop. the whole set up was 375 supplied and fitted but that was a couple of years ago..
  32. #31
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Quote Originally Posted by Khufu View Post
    Thats what i was getting at. Not so bad when i jump into my MK2 Golf as the vision is excellent but anything else you forget you dont have them! Few close ones with the folks car!
