Results 1 to 7 of 7
    Lex
    Lex's Avatar
    Mar 2008
    364
    help needed bout oil in coolant reservoir
    hello chaps
    i've had many problems with my 2.0tdi 53reg a3 as most others have also
    about 3 or so months ago i had the cylinder head done due to leaking coolant, this sorted my problem with the coolant but now i see that there is lots of thick gloopy oily substance in my reservoir. i have also been getting through way too much oil recently compared to what i use to.
    now does this mean that its likely the head gasket has gone AGAIN? or maybe after the cylinder-head was done the whole system wasnt flushed out and therefor there is all this gloopy mess left in my engine
    i would be very annoyed it if was my head gasket again because im sure i've had like 3 now.
    If anybody could shed some light on this for me would be a huge help
    cheers
    lex
    now : A3 2.0 TDI, ST-3 remap, coilovers, matte black rs6 alloys
    800 spent on my car in a week, is that excessive? B***ocks is it
    Sep 2009
    Mid Sussex
    162
    Did you get the head re-skimmed before if was put back on?
    A3 1.8t quattro -
    THS high flow manifold, S3 milltek, Forge 007 DV, THS engine mounts, Performance Haldex Controller (blue), Panel filter
    Coming soon - FMIC, Hybrid K03 Turbo, Custom downpipe & high flow cat
    Sep 2009
    Mid Sussex
    162
    It could possibly be where it wasn't flushed out properly, however if you oil consumption has rocketed then you may have already answered your own question
    A3 1.8t quattro -
    Lex
    Lex's Avatar
    Mar 2008
    364
    the garage which took out the work should have done everything that was needed.
    is it likely that so shortly after having all this work done the head gasket can go again? surely not
    so bloody annoying if that were to be the case
    Sep 2009
    Mid Sussex
    162
    If the head wasn't skimmed then yes! How long did they take to change the head? As most garages need to send the head off to a local machining company
    A3 1.8t quattro -
    Lex
    Lex's Avatar
    Mar 2008
    364
    i think the whole head was replaced with the new redesigned head from audi and swaping the old one
    i think anyway
    Sep 2009
    Mid Sussex
    162
    OK that's good if they did do that.
    I don't want to scare you but it is possible that the bottom end needs skimming I have seen this before on the other cars, especially as you said this the third time.
    I'd personally flush the system again, take it for a drive and then do it again to make sure. Then keep an eye on the oil and condition of your water, and go from there.
    If it was less then six months ago then I'd take it back to the garage who did it.
    A3 1.8t quattro -
