Chris NottSky Insurance
Results 1 to 12 of 12
    Jul 2010
    55
    3.2 v6 not so smooth acceleration?
    All you guys and girls out there with the V6 DSG...
    Is you acceleration smooth? Mine seems to jolt off from stand still.
    The only way to make the acceleration smooth is to let it start to roll and
    then ease your foot down. If you apply any pressure to the throttle before
    you let the box do its thing you get a mild whip lash
    Do you guys get this or is this a box issue?
    Thanks, Nez
    Sarah's A3's Avatar
    MODERATOR V6 S3 Hybrid
    Cheshire to Perth AU
    5,919
    Wow theres a few threads tonight on the 3.2s lol
    Mine does that occassionally, did it more before I got the hesitation sorted, its smooth now. I sometimes notice it when its colder or damper outside! No idea why! But I tend to put my foot down anyway so its fine lol
    Has it had it DSG oils changed recently??? maybe its due. Do you get any clunk noises etc from the box???
    Jules86's Avatar
    At work most likely
    Helicopter Champion
    May 2010
    241
    Your mechatronic unit has gone
    Sarah's A3's Avatar
    5,919
    Not sure if its the Mechatronic unit but this may help with issues that can affect it
    DSG / Mechatronic Issues - ClubTouran.net
    Hope you get it sorted soon Nez
    Jules86's Avatar
    At work most likely
    Helicopter Champion
    May 2010
    241
    Jolty acceleration from stand still is the main sign of a faulty mechatronics unit. Also lurching while slowing, for a roundabout etc are a major sign
    Jul 2010
    55
    Thanks People. Im sure I remember hearing this is an expensive job. Am I right?
    There's no clonking etc... Yet, Just a little jolty occasionaly. I imagine the Gear box oil
    could do with a change now to be honest.
    Sarah, I've found the same. Had the hesitation sorted on the weekend and its definitely
    better but still not perfect.
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    I wouldnt worry about it, if its just a snatch on take up and shows non of the other synptoms on Sarah's link then its just the nature of the beast. Mine has done that for the last 30k miles. It did get better after the remap but it also is worse when its cold and after about 30 miles is almost fine..
    It hasnt got any worse since i have had the car fron 12k miles to 48k miles.
    Jul 2010
    55
    Cheers Pad.
    Was flicking through the box earlier and noticed that its only noticable when in auto.
    If I use the paddles or the stick shift its fine.
    Im kind of getting used to it now so just give it a little blip then pull away.
    It just gets a bit annoying when needing to pull out of a junction quickly
    and you look like a right Plonka when your car leaves your head behind.
    Sarah's A3's Avatar
    5,919
    Haa haa enjoy it! Least its a flying start!
    edition's Avatar
    Nov 2007
    1,417
    Get the rear engine mount insert..... I recon that might help a jolt.......
    TQS
    Aug 2005
    Manchester
    267
    I'm also getting the jolt from setting off in first too - i read somewhere that it is possible to recalibrate the dsg unit by resetting it - has anyone with the same problem done this and solved the problem?
    All other gears are fine as are the upshift and downshifts through both paddles and normal although i do find that the car races up to 6th gear when driving normally - is this also a feature of the dsg box?
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Hi TQ
    Yea the box likes to head for 6th as quick as it can, you learn to control it by giving it a fraction more pull in the gears and it holds back from changing. This was a major factor why i didn’t like the DSG in the S3 where it continually changed out of the rev band and off boost at normal driving speeds. The V6 is a far better engine for DSG. The jolt from pull away is again very dependent on how much throttle you give it, its trial and error but try giving a bit more when pulling away, you can back off straight away if need be. After a while you learn to get smooth pull offs. you need to pull away with some revs, dont let it fluff off the line unless you let the brake off, give it half a second then hit the gas.
