Chris NottMonster Motorsport
    Jun 2010
    46
    APR stage III with stock catback???
    I have recently purchased the stage III kit from APR for my 2008 S3. I have a question as to what catback modification is necessary to compliment the kit. As of now I cannot purchase an upgraded catback (ex. miltek) because in order to do so I would need to import it and the emission's law in my country won't allow it. Even if they could be persuaded the tax on the catback would be devastating. The laws on car modifications here are crazy. I could be fined for driving 19 inch rims instead of 18; things are so strict. That leaves me with two options; fabricating the catback here or sticking with stock. As to the first option I am not sure as to the reliabilty of having it built to fit my car. The question is whether I can stick with the stock catback and fabricate the downpipe? What would be the implications of this? Would the car run the same? Overheat? Would I be causing any damage and if not would I be utilizing the the full power of the kit? Do I need an upgraded catback?
    gaz m's Avatar
    Sep 2009
    NORTH WEST
    148
    Hi Mate,
    What bhp is the APR stage 3? I ran my Revo stage 2+ for a month or so on the standard exhaust whilst waiting for the Miltek cat back exhaust to turn up! The revo agent phoned Revo and were given revised start setting to use just to be on the safe side, possibly somewhere between full stage 2+ and stage 2. Once my Miltek was fitted they turned up the settings again for me.
    What I found was the stock exhaust was working well and sounded great whilst not as loud as the miltek but not as restrictive as I expected! There were no problems with over heating or restrictive air flow but as I said above the settings were turned down slightly to act as a safety margin
    It may be worth a go to see what you think?
    What country are you in? Is it possible to vist another country at a later date and arrange a new exhaust fitted then?
    Good luck with your Quest.
    Gaz
    Black 996 C4S
    B6 S4
    Black S3 Revo 2+ sold
    All options + Miltek TBE, Revo 2+, HPFP, RNS E, Bose, Alpine Ipod interface, TTRS Brakes
    For sale unfitted Forge catch can kit, open to offers?
    also standard S3 factory exhaust?
    Jun 2010
    46
    Engine hp at about 410 without meth. I really am not looking for noise cause the cops would pull me over for it. It could be a while or possibly never until I got an oem aftermarket upgrade and I definately don't want to put out cold cash and not get the full potential of the system (lower start setting.) I could have a system built to fit the car locally. Question is whether that is acceptable or should I stick with stock?
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    it sounds like your only option really is to get one manufactured.. theres nothing wrong with custom made exhausts as long as the company is well renowned!
    Gone but not forgotten......
    S
    3 - Phantom Black - Black Optics - Most Extras
    Mods: Revo Stage 2+ - 18" BBS ch/Michelin PS2 - Recaro OEM Buckets - Milltek TBE NonRes/Sports Cat - Evoms Intake - APR hpfp - H&R Springs/ARBS F&R - Sachs Clutch/Luk DMF - AP Racing 6 Pot BBK - 10mm Spacers - Black Rings
    Mods To Do: Full Retrim - MY11 RNSe - Coilovers- Plenty Carbon
    gaz m's Avatar
    Sep 2009
    NORTH WEST
    148
    Shamrock
    I was running about 330/ 340 bhp on the standard pipe with no issue's but I realy would suggest my last Idea is not an option for you at your predicted bhp level. Have you fitted a hybrid Turbo to gain that power?
    It sounds like a localy produced custom exhaust is the only way to go as you wont reach that Bhp easily with the Stock system as I do suspect far to much of a restriction for your set up!
    Gaz
    Black 996 C4S
    B6 S4
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    The cat back is not as restrictive as the downpipe/cat but with stage 3 tune it would be worthile getting a custom 3 inch, as there's a lot more gas going in that needs to get out, and with that level of tune all the small details make the difference.
    Interesting you went with the GT28 they are a lot more laggy then the K04 and only perform better above 5.5k... But nice anyway where you from?
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
