JMB RetrofitsVolks Autos
Results 1 to 35 of 35
    Sep 2010
    Staffs
    33
    Number Plate Bulbs
    Guys,
    New to the forum after purchasing an 05 plate sportback sport, also new to audi's.
    Been replacing the front sidelight bulbs and number plate bulbs for led's, the front sidelights I replaced with canbus friendly ones off ultraleds which work a treat, no errors, I forgot to get canbus friendly number plate leds, as a result I got the usual flicker and off it went, I managed to get them work but only when a normal bulb was used alongside the led, decided to put the originals back in, but neither of them come on now, just get the message that the bulbs are out on the dash, double checked the connections on the bulbs and all seem well, seems like the system has got confused, even tried the battery off for ten mins, no difference, any pointers ?
    Also had it on a diag machine today and it flags up fault in circuit, voltage on that circuit is just under a volt, tested the bulbs and they are fine, so something is not happy.
    Gaz.
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    hmm thats a weird one mate, hopefully someone will be along that can help you
    Moved to the Darkside click below:
    Sep 2010
    Staffs
    33
    Me too, got me baffled at the mo.
    v1raj's Avatar
    Apr 2009
    279
    Have you attached resistors to the light?
    I did this mod last week and mine wouldnt work without the resistors in. No problems after that.
    I'll get some pics if needed.
    2006 Audi A3 (8P)
    Spec - 2.0 TDI l DSG l Sprint Blue l Leather Interior l 18" RS6's | H&Rs | S3 Front | 6k Bi-Xenons | EMTuning DPF Delete Package
    Plans - BBS
    Fossie
    Rhubarb Triangle
    3,969
    Maybe you have to clear the fault on the diagnostics before they will work.
    Can I ask which of the three choices of LED sidelight bulbs you got - 1 at each side, 2 at each side or 1 at each side and 2 at the top ? I got some with 1 led at each side and needed to put resistors on them to get them to work. They also failed the MOT because the testers eyesight said they gave out a blue light which was not acceptable !!!
    Sep 2010
    Staffs
    33
    The front sidelights work fine they have built in resistors, they are the ones that have two on the side and two on the top, these worked a treat first time round.
    As for the rears, I'm exchanging the non resistor type for the ones that have built in ones which I should of ordered first time round, the problem is that the fault has been cleared yet it will not light any bulb even the orginals, it is though the system stills thinks the bulbs are out/blown even when the fault is cleared.
    Gaz.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    clear the faults bud, then try the bulbs the other way round i suspect youve put them in the wrong current flow direction, being leds these would not accept power and confusethe system
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    Fossie
    Rhubarb Triangle
    3,969
    Do you still only have < 1 volt across the two terminals with both original bulbs in place ?
    If so then I think you will need an expert like NHN on this forum to help because the central electrics module would seem to have got seriously confused !
    Don't think there is a specific fuse just for number plate lights - has anything else stopped working ?
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    V1RAJ - post some pics, is yours as bright as this, mine below:
    Sep 2010
    Staffs
    33
    I wish they were that bright, I took them both out, I'm just trying to get the old bulbs to work again before attempting to put some other led's in.
    As for current flow yes this would affect the led bulbs but not the originals, I haven't measured the voltage with the bulbs in, surely if had 12volts there the bulbs would be lit, I have looked at fuses none blown, there isn't a specific fuse just for number plate lights, there is only a 40amp fuse for left hand side lighting and another for right hand side lighting, and another for interior lights, everything else seems happy as larry.
    Gaz
    v1raj's Avatar
    Apr 2009
    279
    As requested, here are a couple of pics:
    Number plate lights with LED bulbs and resistors in place (resistors were soldered in afterwards):
    How they look:
    Pretty happy the results. Makes the rear look a lot better.
    2006 Audi A3 (8P)
    Plans - BBS
    Sep 2010
    Staffs
    33
    Thanks guys for rubbing it in, will hopefully get to the bottom of mine and at least get some light back there. Candles are looking good at the mo.
    Gaz.
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    sorry for getting off topic mate...hope you get it sorted
    Sep 2010
    Staffs
    33
    No probs, glad to see they will be worth the effort when I get 12v back there.
    Gaz.
    v1raj's Avatar
    Apr 2009
    279
    Quote Originally Posted by gazcallyt View Post
    Gaz.
    lol not trying to rub it in at all mate, just showing you what you have to look forward too
    As been advised, if you have vag-com, get the fault codes cleared and try again.
    Let us know how you get on bud.
    2006 Audi A3 (8P)
    Plans - BBS
    scottie123's Avatar
    Oct 2008
    1,888
    You may want to check the bulb holder. They are the worst design in the world, and can sometimes have a very poor connection.
    In the end , I bought new bulb holders, as I got pissed off with the number plate lights going off and on when ever they wanted.
    ~May be worth trying to connect the bulb without the holder, so you can eliminate the bulb holder as the problem. Just use a couple of wires to connect the bulb to the contacts in the housing.
    Also, to make things easier for you, a lock and unlock from your keyfob should be adequate to reset the error and return power to the lamps. Will make it easier for you when trying the bulbs and connections.
    Sep 2010
    Staffs
    33
    Cheers guys, will eliminate the bulb holders tonight, will also get the multi meter back there to see if the voltage changes at all.
    Gaz.
    Sep 2010
    Staffs
    33
    Right tested everything and its got to be the control unit to the lights I am only getting 0.60 volts with the lights on, all faults cleared and still not reading 12 volts, even with the lights off there is 0.45 volts at the terminals.
    Gaz.
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    so what does this mean mate? new control module?
    Sep 2010
    Staffs
    33
    Looking that way, will try and trace it back, keep you posted.
    Gaz.
    scottie123's Avatar
    Oct 2008
    1,888
    Bit of a long shot, but have you trapped a cable somewhere when routing around . It may be possible that a cable has been damaged and is dragging the 12v down to ground which would you give you a very low voltage reading
    Sep 2010
    Staffs
    33
    Scottie,
    Haven't really had a route around to be honest to trap a cable, its booked in audi in a weeks time, see what they come up with, in the mean time just waiting for me new haynes manual to arrive so at least I can get a circuit diagram for it to see where the feed actually comes from.
    Gaz.
    Sep 2010
    Staffs
    33
    Right peaked at the wiring diagram for the lights basically one side of the circuit goes to earth and the other goes to the control module which controls all of the lights, now for the interesting part the feed that supplies the number plates also feeds what looks like the light switch illumination, now this works, so head scratch well and truly on, will have to wait to see what audi come up with as its stumped me.
    Gaz.
    scottie123's Avatar
    Oct 2008
    1,888
    If that is the case, have you tried testing between to the light switch and number plate section for continuity etc.
    Just to purely eliminate the basics.
    Sep 2010
    Staffs
    33
    Scottie,
    Haven't tried that yet, going to test the earths tonight to make sure there is no voltage leaking to it.
    Gaz
    Sep 2010
    Staffs
    33
    RESOLVED AT LAST
    The metal prongs on the bulb holders were not touching the contacts on the car, instead they were been lifted up by the plastic in between the prongs, little bit of bending later, jobs a good en, now to get the leds in her.
    Cheers to all for guidance.
    Gaz.
  28. #27
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    ahh thank god you got sorted mate, let me know what way you go about installing the LED's
  29. #28
    scottie123's Avatar
    Oct 2008
    1,888
    Quote Originally Posted by scottie123 View Post
  30. #29
    Smoothie's Avatar
    Apr 2010
    Lurgan N.I
    1,431
    Someone was on to something
  31. #30
    Sep 2010
    Staffs
    33
    They were, cheers scottie, I even checked them how many times, it was only when I decided to take the bulbs out, and look very close at where the prongs were ending up I spotted it.
    As for LED bulbs, probably end up putting the normal led festoons in with resistors across, what is the recommended resistor ?
    Gaz.
  32. #31
    b19ctr's Avatar
    The King of Cannock
    Aug 2007
    Cannock
    634
    Gaz not sure if your interested but I've got a set of festoons and resistors ready to go there yours for a 5 if you want them drop me a pm.
    Chris
    Air, OZ, Tarrox, on a TDI
  33. #32
    heeman10's Avatar
    Audi driver since Dec 08
    Dec 2008
    Somerset
    388
    Mine did this when I fitted my LED bulbs a few months back, crappy little tangs!
    .: 2005 Dolphin Grey A3 2.0 TDI Sport :.
  34. #33
    Jun 2012
    Bristol, UK
    54
    I just had this exact same problem. Thanks to this thread it's solved.
    A3 8P 2.0 TDi Sport
    Mods so far...
    Ashtray delete
    LED upgrade
    To come soon...
    CH/LH lights
    Red ambient lighting
  35. #34
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Quote Originally Posted by t0ph0id View Post
    I had this problem too but never managed to get the LED's to work so put the orginal bulbs back in bit nervy about trying again as it took ages to get them working again..
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
  36. #35
    Jun 2012
    Bristol, UK
    54
    Quote Originally Posted by JamesO View Post
    All I did was ever so slightly bend the two connector prongs so the stuck up a bit further to make contact properly.
    Give it a go.
    A3 8P 2.0 TDi Sport
    Mods so far...
    Ashtray delete
    LED upgrade
    To come soon...
    CH/LH lights
