Sky InsuranceJMB Retrofits
Page 2 of 2 FirstFirst 12
Results 41 to 44 of 44
  1. #41
    scottie123's Avatar
    Oct 2008
    1,888
    ok next question peoples
    Exactly how bright are your leds when viewed from close (ie 1 meter away) at the optimium position for brightness?
    I mean, Do the led's when you look at them directly burn holes in your retinas? Or is it not possible to look directly at the internal led as it is hidden by the refractor lense.
    Thank you
  3. #42
    Dean's A3's Avatar
    TDI S3 Hybrid
    May 2010
    261
    I would say they are very bright from even 2 to 3 mtrs away at full brightness, next day after I fitted the headlights with the DRL's on at dusk, the reflections on buildings and other cars at a distance made me think I had my headlights on, you can look at the LED's directly at full brightness but it's something I would not recommend at close distance.
    Around where I live there is a chav who has a facelift A3 with DRL's and I don't think he uses his headlights only his DRL's!
    Best compare yours with a facrory fitted one if you're having difficulties with adjustment.
  4. #43
    scottie123's Avatar
    Oct 2008
    1,888
    if I had one handy to compare to that would be great. But unfortunately I live in Norfolk, and the tractors round here haven't got up to speed yet on drl's.
    Thanks for your help Dean, that has clarified another question for me. Yes the led's will burn your eyeballs if you try and stare them out LMFAO
  5. #44
    27,099
    Quote Originally Posted by scottie123 View Post
    Had me chuckling away lmfao
