Results 1 to 9 of 9
Thread: Tyre Size
    B111COR's Avatar
    St Andrews, Fife
    26
    Tyre Size
    Used the search but just cant find what I'm looking for
    Would I have any issues with a 235/40/18 tyre on 8" rims on a standard set-up Quattro S-Line, I know 225 is the way to go, but I really need some rim protection for the wife
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    Your speedo would become slightly inaccurate, as the rolling radius would be grater, your speedo would under-read slightly more.
    Go on Tire-Rack and it will tell you the percentage change in your speedo accuracy.
    The steering would become a bit more numb as well and there would be slightly more sidewall flex.
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    B111COR's Avatar
    St Andrews, Fife
    26
    Quote Originally Posted by akash_sky1 View Post
    Surely the width of the tyre wouldn't affect the speedo? Its 225/40/18 on at the moment on a 7.5" rim
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,146
    Quote Originally Posted by B111COR View Post
    It won't just be the width of your tyre that increases, it will be the side wall depth also.
    225/40 has a wall depth of 90mm
    235/40 has a wall depth of 94mm
    B111COR's Avatar
    St Andrews, Fife
    26
    Ahh, didn't know that, thanks guys, may just stick with the 225's and ban the wife from driving !!
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,146
    Yeah, I didn't realise this either at first.
    Basically, changing the width has a knock on effect that changes the whole tyre (diameter and circumference, but not the rim that it fits).
    Why don't you buy some 225/40's which are designed with rim protectors already??
    Mar 2009
    Staffordshire
    1,177
    My Eagle F1's have a bit of a rim protector
    B111COR's Avatar
    St Andrews, Fife
    26
    Quote Originally Posted by three View Post
    I already have Vredestein Ultrac Sessantas 225/40's, they do have rim protection, but just not enough
    May 2010
    2,502
    someone said once that you can code your tyre size in vagcom. so if you do go for a different tyre you can code it to make the speedo accurate. you have to have the same width of tyre on all 4 corners as well cos you have a quattro, and you may get some rubbing but it depends on the make cos they all have different shoulders and some rub and some don't - apparently.
    2006 Phantom Black A3 2.0T S-Line.
    DSG | 18" BBS Pescaras | Rear Parking Sensors | MFSW | Symphony II | BOSE | Auto lights/wipers | Half leather
    MODS : '09 tail lights | TT vents | Weitec Hicon GTs | RNS-E 2010 | Controls Pack (Red Stitching)
    PLANS: Dumbos | 8P3 S-Line Rear Bumper | OEM Parking Sensors
    GONE BUT NOT FORGOTTEN:
    2005 Ebony Black A3 1.6 Sport tiptronic. You will be missed!
    1997 BMW 316i Coupe M-Sport. You won't be missed quite so much!
