Sky InsuranceEM Tuning
    Jun 2010
    East Manchester In the Hills !
    677
    Removing Fog Lamps and Rear lamp clusters
    Guys
    Is there any how to's about showing you how to remove the front fog lamps as I have a spider inside mine which has weaved a web and then died. I need to split it apart and clean it out.
    Also does anyone know how to remove the rear light cluster as the sub in the left hand panel is causing the light cluster to vibrate as i dont think its in properly.
    Cheers in advance
    Goochy
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    not to sure on the fog light but if yours is a 3door then its very easy in the boot there is a round cover on each side of the boot take that off then with a screwdriver undo the screw then push the light unit towards the pavement / road whichever side it is then it should come off easy
    ​She is back on the road yay!!
    May 2010
    2,502
    yeah rear light is in the manual. front fog might be a bit more tricky...
    2006 Phantom Black A3 2.0T S-Line.
    DSG | 18" BBS Pescaras | Rear Parking Sensors | MFSW | Symphony II | BOSE | Auto lights/wipers | Half leather
    MODS : '09 tail lights | TT vents | Weitec Hicon GTs | RNS-E 2010 | Controls Pack (Red Stitching)
    PLANS: Dumbos | 8P3 S-Line Rear Bumper | OEM Parking Sensors
    GONE BUT NOT FORGOTTEN:
    2005 Ebony Black A3 1.6 Sport tiptronic. You will be missed!
    1997 BMW 316i Coupe M-Sport. You won't be missed quite so much!
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    From what I remember with the front fog lights, you remove the plastic grille first by pulling it out and then unscrew the fog light - 3 screws.
    VCDS USER
