Badger5Sky Insurance
Results 1 to 21 of 21
    Dec 2009
    80
    Anyone know how to change the TTS badge to a S-line badge on a FBMFSW?
    Just got the new s-line badge in the mail, but how do I change the old one?
    Do I need to take out the airbag or is it just plug and play with a screwdriver?
    And dows anyone got the partnumber for the alu pedals for the S-tronic? I'v heard that its just a clip on and you don't need to mess with the gasspedal??
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    Need to take it apart matey, airbag out wheel off, VERY CAREFULLY detach the aluminium trim bit, do not break/scratch this as it's not a separate part that Audi can supply if you fudge it up
    Can then pop the badge out, put it back together and put the new badge in place
    Currently driving a 55 plate Ford Mondeo ST. But as Arnie once said...
    I'll be back!!!
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    As the young man says.
    Dec 2009
    80
    Damn! Hate it when it looks so easy!! Isn't it a hassel to put the steering wheel on again in the right angel etc?
    What about the pedals? Do I need to remove the gasspedal or is the break/gass pedal just a clip on? I have seen that the dead pedal is sold separately and not in a package deal..
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    mark the splines, youre making a mountain outta a molehill
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    I'mRonBurgundy?'s Avatar
    Lets make that kitten purr...
    543
    Brake pedal cover just pops on. Accelerator is a complete replacement unit (well at least mine was). Easy to fit but worth reading one of the many retro-fit guides first.
    2008 A3 1.8T FSI S-line Phantom Black, Bose, iPod Dock, Front Centre Armrest, Storage Pack, Aluminium Pedals, H&R Spacers, Eibach Pro's, Ambient Lighting, Pressed plates with Ingolstadt surrounds.
    Dec 2009
    80
    Yea! I'v heard that to, but also heard that you can buy a complete pop on sett. Never found it but I don't wanne mess with the accelerator
    Dec 2009
    80
    Why do i need to take the wheel off? Is it not just the airbag that must come off?
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Yup
    Unscrew the airbag from the back and you can change the badge, no need to remove the wheel.
    27,096
    Well everyone has there methods but to SAFELY do it without the remote possibility of any damage, then remove the whole surround trim so you have complete access to the rear of the badge holder, it can be a reeal bugger tbh, then detach accordingly, I always do it this way.
    The spline should already be marked into the metal which is center as should the wheel by audi factory, if there are no marks to define the center or yours is of center, then note where they were positioned.
    Dec 2009
    80
    Thanks! Its no way the airbag will go off in my face when I remove it Im going to try t take off the airbag and leave the steering wheel on. Dont wanne start removing all the parts if its possible to do it just whem airbak off.
    Anyone kjows where I can get the black s-line grill from? Hate the crome surroundings....need it inn black
    gynads's Avatar
    Oct 2009
    338
    can anyone tell me how to remove the aluminum trim once the airbag is removed please? Does it just peel away, any other screws/clips etc to remove?
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Peel away
    27,096
    Just lever it very slowly a little bit at a time on each corner, then slowly it will lift of, it has pressure clips as part of the unit as such to hold it into the wheel, when I say slowly I mean slowly as break that & its not cheap, dont do one corner fully then next, little bit on each one until all out.
    gynads's Avatar
    Oct 2009
    338
    Is it prudent to use some sort of plastic trim lifter or spreader card etc? or will it come off by hand?
    27,096
    NO, dont use anything but your fingers/hands, or you'll indent the plated plastic, trust me on this, it may seem well in there but time & patients are all you need.
    Dec 2009
    80
    Can anyone give me a clue to where to buy LED (or any white light) numberplate lights that wont give an error on a 2010 a3? tried 3 kinds here inn norway with no luck
    gynads's Avatar
    Oct 2009
    338
    Mine gave no error code and look great, ill try find the e-bay link i bought them from. I bought the ones with the holder first , but are of very poor quality, i just bought the bulbs the second time and was perfect.
    Dec 2009
    80
    cool thanks! You got a 2010 aswell?
    gynads's Avatar
    Oct 2009
    338
    I wish money bags! Mines an 07 S3
    Dec 2009
    80
    waiting for a dealer here in norway to find out waht kind of LED i need for the 2010. It works fine for a 2007, but not the new facelift....
