Chris NottEM Tuning
    col6821's Avatar
    Feb 2006
    Warwickshire
    175
    Quattro Chassis Alignment - What's Adjustable?
    After fitting the lowering springs I did a bit of digging on here regarding 4 wheel alignment and have found a local tyre fitters with the Hunter alignment equioment that appears to be favoured by those that have already completed this.
    They offer a free check, and have advised to budget for about 70 if everything is straight forward, but the guy couldn't say what he's be able to adjust until he's seen the car (never done an A3 quattro before).
    I'm assuming that the front toe will obviously be adjusted, along with the rear toe to give the correct thrust angle, but is there any castor/camber adjustment for front/rear?
    Col
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    517
    If i remember correct when i did mine castor and camber on the rears on the front there is a lot you can do by basically doing things like loosening the subframe bolts may get you a bit of movement same with the arms then there is the normal track etc cant remember to be exact but if i do any geo's this afternoon i will look on the pro-align machine
    Phantom Black S3,Giac stg 1,Evoms intake,Lamin-x
    (to do list,update signature pic)
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    AFAIK from just having mine done,you can do the toe,and camber but not castor.
    col6821's Avatar
    Feb 2006
    Warwickshire
    175
    Had a full alignment check yesterday, well impressed with the Hunter alignment kit, it even tells the operator how and where to adjust the car!
    All toe and thrust angles are now spot on, the machine doesn't report on castor, and the camber settings are on the margin of being in tolerance but couldn't be adjusted. I suspected that due to the lowering effect that front camber would increase anyway, so I'm happy.
    Got quoted 70, but the guy did it for 60 including before and after report and the difference is quite dramatic.
    Thanks for the guidance above folks.
    Col
