Volks AutosMonster Motorsport
Thread: alarm problem
    housey11's Avatar
    Aug 2010
    25
    alarm problem
    Hi i have a problem with my 04 3.2 quattro sport. The alarm has started to trigger randomly. The on board computer shows the bonnet is open which is setting the alarm off.Well the bonnet is well and truley shut. Any one with suggestions would b much appreciated......think the neighbours are not overly happy being woken at 3 in the morning.
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,851
    check for water around the ecu or in the boot,under the carpet driversside
    Full leather/19"wheels/cruise/
    Watty's Avatar
    ..... (_!_) Sarah's A3s #1 Fan
    Railway Line Champion
    Sep 2007
    Perth, Western Australia
    406
    Is the bonnet switched controlled, if so check the connections etc. on it as it may be something simple??
    Audi A6 Avant (2002) 2.5 V6 Quattro. Sunroof, Bluetooth mp3 Xcarlink, 6cd, xenons, tints, ST3, 18" RS6s
    I have VCDS and I'm not afraid to use it, well, a little bit?
    housey11's Avatar
    Aug 2010
    25
    front wheel arch liner badly split(drivers side) torrential rain for the last few days ......which is when it started. New liner in garage will get fitted asap and hope for the best. cannot feel moisture anywhere though.Needs fitting anyway so "ill do it tomorrow" really will become ill do it tommorow. many thanks for words of wisdom
    wesley's Avatar
    Giac Extreme+!! Lovin it
    Feb 2007
    Manchester
    322
    Will probably be the wiring to the bonnet sensor. Cant remember off the top of my head where exactly its located, im sure someone will come along to tell you.
    07 Suzuka Grey S3, Giac Extreme plus map, Autotech HPFP, VF Engineering CAI, 18" black rims,factory tints,fbmfsw,Mk 2 RNS-E,CH-LH lights.puddle lights,Bose,Shark fin, Lamin x lights & Fogs.Full TBE miltek, 09 White DIS,Buckets,LED conversion,TPMS.
